Cigarette lighter fuse
Old Oct 31, 2024 | 01:01 PM
EdJennings's Avatar
2003 C240
I have no power to the cigarette lighter. I think years ago a coin may have fallen in the lighter well and shorted the fuse. I’ve never been able to find the fuse, nor have I figured out how to access the lighter and wiring. I added a receptacle on its own fused circuit under the dash 18/20 years ago, and it’s been fine ever since. Now I’m needing a second plug. Can anyone help?
Old Nov 1, 2024 | 05:08 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
If you search here you will find the W203 fuse diagrams.
There's one for the lighter.
To get to the lighter, you need to pop up the panel that had holds the shifter bezel and remove the cupholder.
I'm sure you can search for it, likely find a youtube video.
I always found that ligher socket problematic.
I put a 3 plug unit in the little storage area under the radio assuming you don't have command,
years ago and disconnected that POS vertical thing. Screwed it in, ran wires out the back.
Then I can close the compartment so crap doesn't fall in there
and make a mess. I ran the wires down to where the cig ligher is and connected it there.
There's many places online you find how to take dash apart.
I posted a photo like 15 years ago.
Old Nov 1, 2024 | 05:17 PM
EdJennings's Avatar
2003 C240
I located the fuse and it was indeed blown. The element end of the lighter socket is trash. I stuck the lighter back in it to keep crap out of it and will pursue other avenues. Thanks for your input.
