Install Of COMAND In C-Coupe
Old Dec 2, 2004 | 10:35 AM
brabusCcoupe's Avatar
Talking Install Of COMAND In C-Coupe
I have searched the forum for part numbers and what i need and im more confussed than ever.
I just purchased the 2.0 command unit and it should be here on Monday.
I also have purchased the XM roady.
Does anyone know what items and there part number for the items i need to do the install.
I know i need the antenna is this a2035407006?
and the c1 and c2 connectors
i also have a2035400909 listed as the wiring harness for the comand by my dealer, this is needed as well, correct?
anyone know the part numbers and is that all i need to order,
Thank you for any help supplied.
Old Dec 2, 2004 | 10:55 AM
Tariq's Avatar
S500 W223 2021
Yes thats it no more things to order
as you said just C1 and C2 connectores and GPS antenna... just plugge then play..
BigSis's Avatar
Former Vendor of MBWorld
Nothing MB related (sorry)
Just wondering... didn't you buy a complete self installation kit? There would be no need to ask those questions if you did.
greetingz,
BigSis
Old Dec 2, 2004 | 11:42 AM
Talking
No, where could i buy this? Thanks.
Old Dec 2, 2004 | 11:43 AM
Talking
Do you happen to know those part numbers? thanks
Old Dec 2, 2004 | 12:16 PM
Buellwinkle's Avatar
If you look on my website I have the MB installation guide with the part numbers. You will also need the AUX cable if you want to use the XM Roady with Comand. Also, it would be helpful to have the instrument cluster removal tool so that you can hide the antena above/behind the instrument cluster. Don't put it near the center vents, the metal grill on top of the dash will block the sat signals.
What part of the world are you in, maybe someone that has done this install can help you locally.
Old Dec 2, 2004 | 12:21 PM
Thanks, ive checked out your website, im in Florida. I have the removal tools. Thanks.
Old Dec 2, 2004 | 03:14 PM
SteveS's Avatar
2003 C230 Kompressor Sedan
I have my Roady antenna on the metal grill, and you barely notice it, at least on mine, since I have charcoal interior, it blends right in. The wire is run along the base of the windsheild, under the pillar cover and over to the unit.
Old Dec 2, 2004 | 07:20 PM
That's good place for it, I had mine under the dash and it was OK most of the time but I got dropouts. Also had it in the hatch area of my coupe and it worked best there. The problem is when you put a sat antena (XM or GPS) under the metal grill. This acts as a Faraday Cage keeping signals from penetrating it.
Old Dec 3, 2004 | 11:02 AM
Talking
Thanks for the informative tip Buell
Old Dec 3, 2004 | 11:56 AM
Tariq's Avatar
S500 W223 2021
Dont know about the part numbers... just got it full package from Mr.Steve...
Regards
Old Dec 3, 2004 | 01:00 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
youll need the Aux cable for the Aux input, if thats how you plan on the XM connecting to COMAND.
Old Dec 3, 2004 | 05:05 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
why didn't you get the updated COMAND (2004 I think) that supports SAT Radio ?
That way it's all integrated into the COMAND display.
That's what CitronC230K_03 is doing, and it's going to be awesome !!!
Carlos
Saprissa@aol.com
Old Dec 3, 2004 | 06:52 PM
yeah, second COMAND i bought for my car.
Old Dec 4, 2004 | 02:53 AM
toki999's Avatar
C230 Kompressor Sports Sedan
Citron, how much and where did you get your comand?
seems like everyone has comand and i don't
i want Comand system!!!
Old Dec 4, 2004 | 05:58 AM
BigSis's Avatar
www.mbenznl.com
greetingz,
BigSis
Old Dec 5, 2004 | 01:57 AM
Talking
Carlos
Saprissa@aol.com
I was told that the 2004 command wound not work in my car because the wiring was different, also i want XM sat. radio and the only one that works with the Mercedes 2004 command is Sirius sat. radio, it wouldnt make a difference then, would it? I have the XM in my Tc and i really like it, and i can add to my other car for only 6.99 extra a month.
Citron, are you going to get the SIRIUS sat radio? Are you doing the install yourself?
thanks guys.
Old Dec 5, 2004 | 10:01 AM
TNblkc230wz's Avatar
C320 Coupe
Is the O4 Command DVD based. and can I hook an NTSC video source to it?
Old Dec 5, 2004 | 11:28 PM
Outland's Avatar
2002 C230 Coupe(M111)
No. The 04 is the same 2.0 unit with a new button. 05 is the new interior. I'm still at a loss why MB even did the 04.5 'upgrade' when 05 is what had the real goodies.
