Electrical problem please help
That would be the alternator.
Did you clean the cables and terminals?
Do you have a battery tester? Where did you purchase the battery?
Take it there and have it tested out of the vehicle. Sounds like a bad battery.
Low Cold Cranking amps, CCA
Can still be 12 v and not enough juice.
OR you could have a parasitic drain.
Most common is the seat modules for electric seats.
That will drain the power overnight,
Lots of threads on that utilizing a relay so they turn off when the car is turned off.
Or jusrt replacing them which is the more expensive option.
Other parasitic drains can be the alarm module battery but that is slower.
Not overnigjht.
Try disconnecting the seat modules with the battery fully chargged, and see if it starts the next day,
Again lots of threads on that. I don't have power seats and one less problem to deal with.
But your situation, one start and then not sounds like the battery,
Not overnigjht.
the metallic interface between the two surfaces can do weird things some times, I had a similar experience a long time ago..
