2004 C320 Gateway Location
I need to Find the Gateway module.
I have a 2004 C320. I was having an issue where the engine would not crank. It would crank / fire up and run and shuts off after 2 seconds. It will do that but after the third time, it won’t crank anymore. I would have to disconnect the battery and it will do it over again for three times.
I had a code with the alarm siren, replaced that and the code went away.
Both my key fob would lock and unlock the door with the siren chirping.
When I put the key into the ignition, I can hear the column lock make the sound. I removed the column lock and verify it moving.
Hooked it up to my scan tool and I see immobilizer fault not letting the engine start.
I see the PIDs for terminal 50, and others all working when turning the from off/ on/ crank.
So I bought a complete ECM, Key, ignition switch, ignition lock, and Gateway from a wreck car. Installed the ECM, Ignition Switch, and Ignition lock. Now the engine starts and I can move the car but the Gateway is not connecting the SRS, ESP, and other modules. Where is the Gateway module located on this C320?
Thanks in advance.
Thanks in advance.
