More Power Please
Old 12-10-2001, 09:06 PM
renncpe's Avatar
w203 c230K 2002
Full Price list
They used a base line dyno on the car assumeing that
the base line was the facory rated HP and Torque, then added the diffrence to the facory rated numbers so there was no need to estmate the parasitic loss of the drive train. I don't have the graphs but i will see if they will send me one.
Renntech 2002 Mercedes Benz C230 Kompressor
Modifications:
Pulley Kit $1695. 2hr
(incl. Renntech High Performance Air-Filter)
BHP Gain 32
Lbs. Ft Gain 50
Total BHP @ RPM 224 @5,300
Total Lbs. Ft. @ RPM 250 @ 2,500 – 4,800
Renntech Rear Muffler with dual tail pipes $688 2hr
Renntech/Apex springs/Fichtel & Sachs Shocks $1295 5hr
Front and Rear sway bars $935 2hr
Lowering Kit (4 Renntech Springs) $320 5hr
Renntech Enhanced Brake Kit (Front & Rear)
(Fits standard 16” OEM wheels) $1,995 per axle 1hr
3-pc. Rear Deck lid Spoiler $375 2hr
Unpainted
Renntech Monolite Forged 18” wheels Front & Rear
Front: 8.5 x 18 $849
Rear: 9.5 x 18 $889
Renntech Decal Set $ 49
I sell Mercedes and Renntech Mercedes if you see anything you like let me know.
Old 12-11-2001, 07:03 AM
Notorious's Avatar
2002 C230 Orion Blue w/ C7, Auto, Bose, and CD changer
Question pulley kit
If we ordered the pulley kit where would we be able to have it instaled and about how much would that cost? Thanks for all the information.
Old 12-11-2001, 07:19 AM
renncpe's Avatar
w203 c230K 2002
Re: pulley kit
It is an easy install two hours labor. If you are handy you could do it your self. Having it done at the Dealer could be a problem depending on the dealership some are cool and would never give you a moment’s grief about warranty issues.
Otherwise I would suggest a private Mercedes shop or a local speed shop. It’s straight a forward bolt on install.
Randy
Old 12-11-2001, 01:37 PM
gab
gab's Avatar
if you work on a groupbuy i'm sure many people will be interested
Hey Randy do you know what is the Boost Level is the Pulley Kit and Pulley Diameter? some of the kits bring to boost between 10psi to 14psi
Old 12-11-2001, 06:40 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Re: pulley kit
Randy
Randy--
With the pulley kit installed, I assume the ECU wouldn't produce any codes that would indicate that the engine has been tampered with? Is this upgrade transparent enough so not to affect the warranty?
Thanks.
Old 12-11-2001, 11:05 PM
renncpe's Avatar
w203 c230K 2002
Re: Re: Re: pulley kit
Originally posted by vadim
Randy--
Thanks.
You are correct the pulley kit does not cause any error codes in the computer. The kit is transparent to that degree; with out measuring the pulley and knowing what it’s supposed to be it would not be obvious.
Randy
Old 12-12-2001, 03:44 AM
  #32
vadim's Avatar
Re: Re: Re: Re: pulley kit
Randy
...So it would be safe to assume that this modification is not going to ring any bells with MB techs (and result in a possible warranty denial), should the car need dealer service, right?
Thanks.
Old 12-12-2001, 07:31 AM
  #33
renncpe's Avatar
w203 c230K 2002
Re: Re: Re: Re: Re: pulley kit
Thanks.
RIght !
Old 12-12-2001, 07:40 AM
  #34
renncpe's Avatar
w203 c230K 2002
Originally posted by RedC230K
ren, You mean to tell me that C7 cars have a different shifter than other cars? Wow. The downside of having the only one in town (so far) is that you can't compare to others!
If you have the C-7 package you already have a short throw shifter If you do not it’s pretty pricy to install it the part runs $510 and 2hrs labor to install. I have not cross referenced it but I think it’s out of the SLK.
I changed mine I did not get the C-7 package. That was a mistake would get now if I had know all the differences.
You can also get the color matched door handles like in the C-7 package. They cost about $63 a side are a must if you have the grey ones.
Randy
Old 12-12-2001, 09:12 AM
  #35
Flashman's Avatar
2002 Mercedes-Benz C230 Kompressor Sports Coupe
[B]If you have the C-7 package you already have a short throw shifter If you do not it’s pretty pricy to install it the part runs $510 and 2hrs labor to install. I have not cross referenced it but I think it’s out of the SLK.
B]
The U.S. C7 Wheel Package includes a short-throw shifter? Are you sure? It is not listed anywhere and when I test drove them, I didn't notice any difference except the smaller plastic piece (more leather) on the C7 shifter.
Can someone else confirm this?
Rick
Old 12-12-2001, 09:22 AM
  #36
tommy's Avatar
2004 Civic Si. FWD for the Win!
Well, when I talked to Bob Brady at Renntech, he said the same thing. So, there's two sources.
But, like you, I didn't remember any difference in the throws. But, I didn't do them one right after the other. That's another reason for why we would need C230 meets in the spring, when things warm back up!
Old 12-12-2001, 10:09 PM
  #37
C230K's Avatar
C250 Coupe 2012
meet in the spring.....think we can meet here in Florida now. how about early Feb. for the 24 hours race?????????
Old 12-12-2001, 10:30 PM
  #38
renncpe's Avatar
w203 c230K 2002
I plan on being at the 24 hour we will have to meet up there for sure.. Hurley Haywood is with our Porshce Dealership I'm not sure if he will be raceing this year or not. If he is I will have to have you meet him.
Randy
Old 12-12-2001, 11:00 PM
  #39
C230K's Avatar
C250 Coupe 2012
Rick, care to join us at the 24 hour, hope you car get's here in time. Well that would make three to go..... that's a start..
Old 12-13-2001, 12:03 AM
  #40
sk-mia's Avatar
1999 BMW 323i
Yet another power improvement
It appears that Wetterauer has a chip that would increase a peak engine HP from 193 HP to 230 HP and peak engine torque from 206 ft/lbs to 236 ft/lbs for $1,295. These are pretty impressive numbers.
Find more at Wetterauer's site for the US at http://www.chip-tuning.com. If anyone gets it, I hope that he/she will let us know.
Old 12-13-2001, 12:25 AM
  #41
gab
gab's Avatar
I checked the Renntech website and their kit for the SLK pulley only can upgrade the engine power to 205hp 220lb/ft so whats the difference with the new kit that offers 225hp 240lb/ft ?
Old 12-13-2001, 12:45 AM
  #42
Lynn's Avatar
Re: Yet another power improvement
That is a pulley kit not a chip.
Old 12-13-2001, 12:54 AM
  #43
sk-mia's Avatar
1999 BMW 323i
Yup, I know...
Yup, I know, I got caught in the web site name chip-tuning, and they have been known for making chips for Audi/VW, which have turbo engines that can be easily chipped. I guess that supercharger has to be done mechanically, that is, with a pulley and all that stuff. But, anyway, it seems to me that they are selling a pretty much the same thing as Renntech, except for $400 less. Would it be any disadvantage taking the Wet instead of a Renntech?
Old 12-13-2001, 01:03 AM
  #44
Lynn's Avatar
I don't know the relative merits of the various turners' pulley kits. Brabus, Dyno-spot and Kleemann make them also. Most claim 230 hp and 250 lb-ft torque. That's a 25% increase in torque and the torque curve stays as flat over the same rev range as stock.
Upsolute Power is claiming similar results with a $325 chip.
http://www.upsolute.com/eng/index.html
Old 12-13-2001, 02:14 AM
  #45
vadim's Avatar
Re: Re: Yet another power improvement
...but it's listed on their website under "Chips For Mercedes" and pulley isn't mentioned anywhere... Are you sure it's a pulley kit?
Old 12-13-2001, 08:33 AM
  #46
renncpe's Avatar
w203 c230K 2002
Different Chips and pully kits
The 2002 230k fuel injection system is different the 2001 SLK 230. The ECU is also different it is now a sealed box before there were flexible tabs that could be bent to allow removal of the cover. The new one has a heavy metal tab that can’t be bent it will require cutting. The changes a chip will make to the system won’t be picked up by the service centers computer but physical changes to the box will be apparent.
I would recommend that you check the chip modifiers warranty; does it cover the chip mod or the whole ECU? Pulley Kits are another item; it’s not a race to put in the largest pulley but the one that produces the best streetable performance there is a fine line between power out vs power consumption of the supercharger.
There are only a few tuners that develop there own pulley kits and tune there chips. The others are just reselling a generic product. I would not let $300 dollars make up my mind between the best and the lest expensive.
Randy
Old 12-13-2001, 01:45 PM
  #47
Lynn's Avatar
Re: Re: Re: Yet another power improvement
Yes. The price is the tip-off. It is much more expensive than the chips and inline with what others are charging for pulley kits.
Old 12-13-2001, 03:43 PM
  #48
vadim's Avatar
Re: Re: Re: Re: Yet another power improvement
I'm puzzled.... Here's what it says under CLK230K:
Tuning type: Hardware Upgrade;
"The kit includes a pulley that maintains the magnetic clutch, a drive belt, fuel pressure regulator
and special air intake pipe for the increased air volume"
However, under C230K and CLK200K :
Tuning type: Alpha (i.e. chip only!)
The "tuned" power and torque are the same in all 3 cases, so are the prices...
So, they must have updated only the CLK230 page and left the other two in "generic" form (copied and pasted from a template).
Thanks, Lynn!
Old 12-13-2001, 09:54 PM
  #49
renncpe's Avatar
w203 c230K 2002
I’m bummed my HID kit did not come in today as expected. Now I will have to wait until Saturday to get them installed if they come in tomorrow. My car should be complete by the end of February. Parts for the C230 are still hard to come by but I expect that by spring we should have a lot more available. I have already lowered the car but I found a full set up with matched springs, shocks, and sway bars. That is due in two weeks. That should finish up the suspension. I don’t believe that is a legitimate chip out there yet most of what I see look like chips for C230K sedan not the new Coupe. I will wait a little longer for that.
BTW a RSX might take me in a sprint like a 1/8 mile but that’s about it.
Randy
Quick Reply: More Power Please
