Accidently pushed wheel bearing crooked
Old May 29, 2026 | 04:16 PM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
I did something super stupid and pressed a rear wheel bearing in crooked due to not paying attention. Got a nice line about 1/4 of the bore which I did try to sand down but I'm afraid to remove to much material. It's hard to show on picture but I need some advice. Would I be able to use this or am I better off getting a used spindle
instead?
Old May 29, 2026 | 09:14 PM
Mikes62's Avatar
Is there a burr inside the bore? If there is, I’d dress down the burr only with a dremel light sanding drum and press the bearing in again. If the bearing doesn't fit tight enough, Loctite make a liquid which will hold it in place.
If the bearing is sloppy in the bore, replace the spindle.
Old May 30, 2026 | 02:51 AM
Dokus's Avatar
Thank you. Yeah, the burr in the middle and to the right. I will try sanding it down.
