Audio Control Dial - it stopped responding?
This morning the rotating dial/joystick (?) placed on the arm rest stopped responding while in any audio mode, be it broadcast sirius, AM, FM, or CD mode. Can't tune to anything by rotating the dial, can't change modes by moving it as a joystick... it just won't do anything. I don't have access to the user manual to see if it's in a weird mode.
Most I could do was cycle power to radio, engine, lock, unlock, blah blah.. no difference.
Anyone have any ideas? Last time it was functional was when it was last parked in the evening. It stopped working when the car was started the this morning. Anyone have any ideas if it is in some kind of a mode?
P.S. I can change presets using the audio controls on the steering, and I can change audio modes using the Radio button on the dashboard.
Thanks for any ideas.
entire radio section is dead...can't use the dial or open the screen.
I haven't started trouble shooting as I'm at work, anyone know where the fuses/relays are for the system?
My cluster nav stuff just shows "----" , same with the audio section.
if anyone has insight...I'd appreciate it before I dig in.
TIA
Both of you guys problem sounded like a defect. Go to dealer if after fidling around with ON OFF it does not work.
Remeber not to use MM for a long time if the car engine is not running.
