Tire Pressure Montior
Old 11-27-2007, 04:18 PM
MBTex's Avatar
2008 C350
Originally Posted by JimPap
Sounds like the system was set when the tires were hot and on a warm day.
Time for a reset. Isn't it under menu accessed by the "system" button?
Also be sure to check your inflation pressure before resetting it.
Yep, they were set when the temps were in the upper 80's. It is a simple process to reset, I just don't want to have to check my tires and reset the system everytime we have a 40 degree change in tempurature from early morning until afternoon as that is pretty common around here during "winter".
It would be nice if we could set the TPMS to only alert following significant changes in pressure that would be caused by a cut or punctured tire. I check my tires often enough to keep them properly inflated on my own and I don't want alerts everytime they change 4-5 pounds due to weather conditions.
Old 11-27-2007, 04:28 PM
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
TP sensors
<<Hey guys, i heard somewhere that the TPMS system on the W204s dont use any RF sensor inside the wheel. Instead, it supposedly uses the cars ESP system to detect if any wheel is rolling with a smaller circumferential diameter; hence indicative of pressure loss. This then triggers the Check tyre pressure warning. If I am wrong and it does use a sensor, can someone take a post a picture of it as i'm curious to see what it looks like. Also, the guys at the tyre shop tells me that any car that uses the RF sensor system will generally have a metal valve stem protruding, so can someone also take a close up picture of their tyre's valve stem too.>>
You are incorrect. See all previous posts on this subject. I posted on some other thread (can't find it now) yesterday that the MB US dealer price (Caliber Motors) for each sensor is $252 which of course is just plain crazy.
So today I called Tire Rack for a price quote since they sell many different sensors on their website where pictures and descriptions of all them are found.
www.tirerack.com
Click on TPMS on the home page.
They sell the exact Schrader sensor (they buy them from MB) used in our W204s and their price is $74.50 each including the required valve stem.
So if you are contemplating mounting winter tires on a spare set of wheels and you want the TP system to be active, this is the way to go. Most likely I will be buying winter tires from them and will make the TP sensor decision at that time.
Old 11-27-2007, 04:35 PM
JimPap's Avatar
2008 C300 Sport, RWD, US
RLE
Nice fine on those sensors.
Do you know if there is an area on this forum so that we can find deals on parts organized to make it easy to find?
Old 02-06-2008, 02:15 PM
walker29's Avatar
2023 EQS 450+
Originally Posted by RLE
<<Do you guys know if we can change the wheels and tires without putting the tire pressure sensors?>>
Yes, you can. If the receiver in the trunk doesn't receive any signals, it's happy.
The factory wheels have a little support boss inside that each sensor sits on. The valve stem and sensor are a unit. The big AMG logo opposite the valve stem on the AMG wheels compensates for the weight of the sensor assembly opposite.
RLE - Have you (or anyone else) actually mounted wheels without the sensors in them? Did it give you an error or anything on the dash. I just got new rims, and I'm debating whether to do the sensor switch from my old rims or not
Old 02-06-2008, 04:16 PM
jrct9454's Avatar
'14 GLK250 Diesel
Yeah, I'm curious, too.
I did exactly that on our '06 Prius, and the small yellow warning light was easy to cover with an equally small piece of black tape....no problem, end of story. [The sensors would have cost almost as much as the wheels I was installing - ridiculous.]
However, I have a sneaking suspicion that the MB is not going to let it go at that - red warning messages on the screen? Constant nagging? Anyone try to run without the sensors yet??
Old 02-06-2008, 08:50 PM
theraj2's Avatar
'08C300 White w P2,MM,Pano
anyone use nitrofil in their tires? I have it on one of my other cars.. and its a much smoother ride
Old 02-06-2008, 09:59 PM
  #32
sou98's Avatar
MB 2008 C300 sport, 2008 Rally blue Subaru Impreza 2.5 SI 1995 MB C280 W202
there is no tires pressure sensors on my C300 Canadian spec car.
The car use Indirect Monitoring Systems.. see first thread.... and I change the snow tires with no problem and it started to monitor after i resetting the sensor.
Old 02-06-2008, 10:21 PM
  #33
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Smoother ride? I haven't heard that before. I thought nitrogen benefits were that is was less susceptible to changes temperature and didn't leak out of the tire as fast.
It has real advantages on the track, but IMO not much in the real world. Personally to me it seems like a marketing ploy. But what do I know, I've never tried it...
Old 02-07-2008, 10:33 AM
  #34
jrct9454's Avatar
'14 GLK250 Diesel
Yeah, well, unfortunately, in the US we get active sensors. I find the whole thing a big pain in the butt.
This is all because some idiots decided to kill themselves by running Ford Explorers with underinflated tires - now we have to put up with this expensive add-on so you don't have to actually think about tire pressures - unitl they're already too low, of course [the sensor doesn't trip unless it falls at least 20-25% below the reference / base pressure].
Anyway, I'll also repeat the question of the moment - has any USA [NOT Canadian] W204 owner run without the sensors altogether, and what shows up on the screen, and for how long, etc?
I could live with Toyota's little yellow light, but not with a message screaming at me from the dash every moment the engine's on.
  #35
walker29's Avatar
2023 EQS 450+
Anyone?
Looking to install new rims without sensors, and I'm wondering if it will cause the system to light the error light.
Old 02-07-2008, 11:04 AM
  #36
Former Vendor
TuneTime's Avatar
Any AMG Thats Around..
Originally Posted by walker29
Anyone?
if you have the Metal stems (sensors in the wheels) and you dont put them in your new wheels you will get a TPM Malf...... Without a doubt....
Old 07-07-2008, 05:07 PM
  #37
rgrpc's Avatar
2008 C300
Yeah it will give you a fault, I picked up some oem sensors on ebay and am having em put on today hopefully it will work, tired of seeing to low tire indicator
Old 07-07-2008, 05:25 PM
  #38
StickyZ's Avatar
W204
you WILL get an error msg (sort of) the little yellow light will blink a few times upon start up and then stay lit when driving. every once in a while a "tire pressure monitoring sys unavailable" warning pops up. hit ok and it goes away until the next time. i have 3 diff sets of tires for road/track/quarter mile straights. i constantly change the wheels on a weekly basis. i have no intention of replacing the TPM's on any of the sets of rubber as it is the biggest waste of technology ever...does any one know where the actual sensor is located? something has to be receiving the signal. i'd love to trick it or simply pull the fuse so the irritating warning light is no longer a factor...anyone?
Old 07-08-2008, 10:34 AM
  #39
jrct9454's Avatar
'14 GLK250 Diesel
Great question, but I fear the receiver is so embedded in the onboard computer system that it simply can't be disabled by something as easy as a fuse.
I despise the TPMS with a quiet passion.....a completely unnecessary complication and expense.
Old 07-08-2008, 12:09 PM
  #40
StickyZ's Avatar
W204
right?! thank you!
Old 07-08-2008, 05:09 PM
  #41
RLE
RLE's Avatar
Who to thank
Originally Posted by StickyZ
right?! thank you!
It's Federal law. All 2008 cars for the US market have tire pressure sensors. Even the lowest form of automotive life, the Kia Rio.
Complain to your congressman, not MB. MB is to blame for everything else but not this.
Old 07-08-2008, 05:54 PM
  #42
jrct9454's Avatar
'14 GLK250 Diesel
Yes, we know it's a federal law - that doesn't make it any easier to live with, or any less of a pain in the backside. I don't "blame" MB, any more than I "blamed" Toyota.
I still routinely note obviously underinflated tires as I walk in every large parking lot. I wish I could believe that TPMS will, as it becomes universal, save all of these people from themselves....but I doubt it.
Old 07-08-2008, 09:41 PM
  #43
RLE
RLE's Avatar
TP
<<Unfortunately, indirect tire pressure monitoring systems have several shortcomings. Indirect systems won't tell the driver which tire is low on pressure,>>
Neither will the direct MB system. Others will, not MB C-Class.
Old 07-09-2008, 12:34 PM
  #44
rgrpc's Avatar
2008 C300
433 is the frequency you need to make em work. The ones tha I got on ebay worked great no more indicator
Quick Reply: Tire Pressure Montior
