Strange noise
how consistent is your noise? like time interval-wise...? do you also hear it while driving...
i'm sure it's minor, but it's very un-merc like. when i have a chance, i'll dig around that area see if anything is loose
I read the manual and there is no mention of such so this could be a European only feature, but from what you said that sounds possible. Or it could be the Hill hold feature which is available in US and Canada.
i'll mention this to my dealer/service rep next time i see them.. the car's functioning perfectly and assuming it's not anything serious i guess i can live with the noise.. just turn up the tunes!
This is Hill Start assist, standard equipment on all W203s, and holds the brake for about two seconds on an upslope with the car in gear provided you have had your foot on the brake. It allows just enough time to move your foot from the brake to the accelerator so the car does not roll back. It does not operate on the level or a downslope.
What it SHOULD do is hold the brakes until the gas pedal is depressed, no matter how long.
This feature was available on American cars about 1947.
my very first car was a brand new '90 240sx, loved the car but it had an intermittent problem.. long story short, kept bringing it into the shop every couple of weeks to try and isolate.. got to the point where the technicians were leaving stuff in the engine bay like screwdrivers etc.. drove me nuts.
seeing that we both have the exact same noise problem, i wouldn't be surprised if it starts popping up for other members too.. and if it's big enough of an issue, hopefully MB posts a service bulletin for it.
my last car was '03 W203 and after a couple of months the driver's seat starts creaking noisily.. turned out to be a common problem and eventually MB posts a service bulletin for it..
when I start the car inside my garage I haven't be able to pinpoint it, I have 1500 mls I will schedule the 1000/3000 inspection maintenace and I will adress this isue I will let you all know what the service department tells me.
I have the same problem with a noise coming out of the glove box/foot well area (sounds like a spring or some little gears not engaging correctly). I have this sound only when I turn the engine off no matter what the setting on the A/C. After the engine is shut off the sound starts for 2-3 secounds.
With your postet part numbers I will go to the dealer and see what they will come up with.
Wonder who else caught it...
