Anyone have luck w/ MB Touch/up paint?
I would have rather had a dent and no chip as you can remove those but anyway I used the MB touch/up my car is steel gray or tenorite gray and it's not even close, the color is really dark. I recently picked up some T/U paint for my 20 year old Porsche 911, since they don't make marine blue metallic it too had to come from Germany only two-weeks
and that paint matches perfectly to my car. Anyone else have issues w/ MB touch/up paint matching?-Ryan
-Ryan
We actually do have the strip, but it's near the bottom of the door and it's absolutely useless for protestion against said a$$#oles.
That reminds me... I should get some touchup paint just in case...
To get a good color match, you have to shake the living bejeezus out of the thing before trying to use it.
Bring it inside [room temp], and then shake it for at least 2-4 minutes - no, I'm not kidding. In addition to everything else, this will give your wrists a good workout.
Then, and only then, try a dab using a toothpick dipped in the paint, and more as necessary.
All of our metallic colored Mercedes cars [going back to an '84 190] have had the problem of the touchup paint looking darker than the factory finish unless you spend a LOT of time mixing the paint first. I have had good results once I started shaking and shaking the container first - when you think you're done, shake it some more.
yea i agree as well, shake it like youre trying to kill it and then shake it some more!! i think even on the bottle it says shake it for 3 minutes or something like that. it helps if you have someone else there to help you shake, then you can pass it back and forth. its a lot of effort, but at least the paint will match.
I like the pens better anyway, so I just needed something to tide me over.
Body shops in my area usually will do touch ups for you pretty cheap. And they do a much better job than I can. You may want to try them if the the chip on the body panel is really bad.
