18s or 19s
Old Feb 22, 2008 | 12:08 AM
Stryder04's Avatar
Benz
18s or 19s
I currently have the 7 spoke stock 17s and im planning on getting some rims late spring early summer. (still trying to find the right ones) I'm a little scare about getting 19s because i think i would need to lower it if i got 19's and i dont know if that would affect my ride quality. thats why i think 18s might be the perfect size for me. I was wondering what you guys thought about the difference in 18s and 19s because im still debating. -thanks
Old Feb 22, 2008 | 12:56 AM
DucatiGuy's Avatar
06 CLS55 AMG
Since you have 17's, going to 18's would be a +1 upgrade, and going to 19's would be a +2 upgrade. There's a couple of important factors to consider when choosing between 18's and 19's. For starters, lets talk about the costs involved. Generally speaking, 19's will usually cost you more than 18's. If not for the rim, definitely so for the tires. Tire selection wise, both sizes offer plenty to choose from, so you shouldn't run into any issues there. Next, you may want to think about the weight of the wheels. Once again generally speaking, due to the fact 19's are a larger rim and will have more rubber surrounding, they usually weigh more than 18's. If you're just into the "show" aspect of a new set of wheels, then the following won't hold true for you, but it is something to consider. The heavier the wheel, the more of an impact it will make on the over-all performance of your vehicle. From acceleration to braking, the heavier the wheel, the greater of an impact it will have on those areas. The trick is to get the lightest wheel and tire combo you can in direct relation to the setup (weight) you have now with your 17's. That way nothing (or not much) will change with the performance specs of your vehicle. With 19's, you'll most likely run a lower aspect ration tire compared to what you would run on a 18. This isn't always the case, but for the most part true. A lower aspect ratio tire will give you the "corner ripping grip" you want from a tire, but at the cost of a little (to some a lot) ride quality. To plainly put it, the ride will get "harder". Here's a rule of thumb you can use, going to a +1 upgrade (18's in your case) will give you 10% stiffer ride, and going to +2 upgrade (19's in your case) will give you a 20% stiffer ride. Now once again, this isn't always true, but something you can refer to quickly if you're put on the spot and need to make a decision. Last but not least, and you touched base on it, the larger the wheel you put, the more it will "lift" your vehicle. Giving it what's known as the "SUV-tuner" look. The rims look great, but the space between the fenders and the tires just looks aweful. With a +1 upgrade, the difference is there, but not as noticeable. With a +2 upgrade, the difference becomes much more evident.... Just some things to think about before you buy...
Old Feb 22, 2008 | 02:18 AM
rdsesq's Avatar
Obsidian Black C350
For ride comfort go +1 (18) for max style go + 2 (19) The ride will be harsher on the 19s.
Old Feb 22, 2008 | 03:55 AM
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
I'd go with 18s
Old Feb 22, 2008 | 08:42 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
^+1
Personally I will go for 19's you can lower the car later on the road, it's so easy to lower this cars, 2 bolts on the rear and 6 bolts on the fronts
Old Feb 22, 2008 | 11:10 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
Originally Posted by JRAMGV8
I'd go with 18s
+1
Old Feb 22, 2008 | 01:47 PM
tmehanna's Avatar
Originally Posted by SoCalCLK
+1
^+1 + I wouldn't fit any size that isn't offered as OEM and as far as I know, the biggest stock offered is 18"
Old Feb 22, 2008 | 06:16 PM
Shake's Avatar
IS300
I'd go with 20"s or 19".
Old Feb 22, 2008 | 07:02 PM
tanktube67's Avatar
^+1
19"
YEA!
Old Feb 23, 2008 | 10:55 AM
PoaMike's Avatar
C300 (W204) w/ MM, P1, & 18"amg's
20inch with 4.5" lip... Can get them crome dipped for $400.
Old Feb 23, 2008 | 11:46 AM
tanktube67's Avatar
Rims look good, the space between the tire and the fender looks right, but the car looks little to high from the ground that may affect the handle and stability.
Old Feb 23, 2008 | 01:24 PM
PoaMike's Avatar
^That car is also lowered with H&R springs.
Old Feb 23, 2008 | 01:47 PM
Savage c-300's Avatar
C300 Sport, MM, P1
+1 on the 19s
Old Feb 23, 2008 | 02:46 PM
tanktube67's Avatar
It's that the case that's why the gap between the tire and the fender looks just right, but I think it looks to high from the ground up.
It could be just me.
Old Feb 23, 2008 | 03:37 PM
PoaMike's Avatar
I see what your getting at but it also could be the angle of the camera? I think its a perfect height, Would like coilovers but that looks to rice IMHO.
Old Feb 24, 2008 | 04:44 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
If you read any of the new articles on the C63 (AMG C-Klasse)- one of the complaints was about the 19" optional wheels on the test vehicles. One article said they ruined the ride and performance of the vehicle.
A little off subject- but my friend has 19" 2 piece Racing Harts on his Lexus and after spending almost $3500 for rims and tires hit a construction cutout in the road and bent all 4 rims. He then paid $900 to have them repaired and re-painted.
I'll be buying 18's.
Old Feb 24, 2008 | 11:16 PM
PoaMike's Avatar
^Ouch... well Im still going with 20"s lol. Im going to keep the 18" amgs in my closet to scare away the boogy man and also incase something like all 4 rims bending ill have back ups.
Old Feb 25, 2008 | 12:50 AM
Stryder04's Avatar
Benz
sell me ur amg rims mike
Old Feb 25, 2008 | 08:50 AM
PoaMike's Avatar
Na, I rather hang them on my wall
Old Feb 25, 2008 | 10:33 AM
Stryder04's Avatar
Benz
have you found any rims u like mike?
Old Feb 25, 2008 | 10:47 AM
PoaMike's Avatar
Click the hyperlink
