Reset learned driving ?
Old Mar 18, 2008 | 09:35 PM
twinspark's Avatar
2008 C280 Avantgarde
Guys.... I tried the ECU reset last night.... and i can't believe the diff!!! a completely diff car,,, I think its now faster than my 3.0 si BMW X3!!!
I love it love it love it !!! ECU reset + 95 Octane all the way
Now,,, while launching from 0 while switching the ESP off,,, the wheels spin for 3 seconds or something then flies away !! Really different
Old Mar 18, 2008 | 10:25 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Training
<<Is this similar to the procedure you described above?>>
Doesn't look like it.
Old Mar 19, 2008 | 12:22 AM
trial0r's Avatar
black c300 sport p1
i drove pretty easy during the break in period so i really want to do this.
is there a way to assure that the tcu learns the most aggressive acceleration possible? i do exclusively city driving so i can't be peeling around everywhere to teach the car to GO.
Old Mar 20, 2008 | 04:38 PM
Lakerz4sho's Avatar
c300 sport
^yeah.. is there?
and how long do you have to drive aggressively before it starts to "learn" your new style?
And is the w204 a Cyberdyne system, Model 101. Does it have a Neural Net Processor -- A learning computer?
Old Mar 20, 2008 | 04:53 PM
jstaneff's Avatar
C-300, XC70, Wrangler
Anecdotal for sure, but ....
Same route, very similar times and speeds.
To: typically 25.5 mpg on the "from start" panel
After the reset, both were 2 mpg higher on the same panel.
I did the reset because I recalled seeing over 30 mpg on that panel on some longer drives just after I got the car, but recently they've gone missing. I'll be doing some longer drives next week, and expect to see them again.
I'm thinking that "learning" also involves such stuff as the fixes you get into with traffic and bad weather, and such. Be an optimist, realize it always gets better, and do the reset. At worst, you can reset it again ;-)
So, do this every 3K miles? I waited until 6K and maybe that was too long.
Old Mar 21, 2008 | 03:02 AM
narky's Avatar
2008 Arctic White C300 Sport 6M
I have a neural net processor. I am a learning computer.
I'll be back.
Old Mar 22, 2008 | 02:09 AM
  #32
CA_Tallguy's Avatar
1997 E420
Just came across the thread. Link to search for reset info added to the homepage of EverythingBenz. (Thanks for the mention, OhLord!)
Old Mar 24, 2008 | 06:19 AM
  #33
Rixter's Avatar
2008 - C200K : 2002 - C200K
Hi Guys,
Is there a run in period? My dealer told me there isnt and that i can drive it like i do and take it long distances as well, "as long as i dont run it on say 100kms for a few hrs as the engine needs to learn my driving patterns"
I have had it for a week and have given in a bit some times? would this cause any issues? should i do a ECU reset ?
Old Mar 25, 2008 | 02:43 AM
  #34
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
Originally Posted by Rixter
Hi Guys,
No ECU reset needed yet, but the manual does tell you to break in engine during 1500 first miles.
They say to run in "C" mode, instead of "S" for the first 1500 miles too and take it easy, and vary the speed like you said you're doing.
So yeah take it easy a bit.
Old Mar 25, 2008 | 06:31 PM
  #35
Rixter's Avatar
Thankyou for the update - damn - iv been runnin it on "S" mode as this is how it come from the dealership. would this have caused any issues?
Cheers.
Old Mar 25, 2008 | 10:40 PM
  #36
mac911's Avatar
Cheers.
No, you'll be fine, just go ahead and follow the procedure now, to be on the safe side.
Old Mar 26, 2008 | 12:30 AM
  #37
Alpha Zero's Avatar
2008 C350
good info, didn't know about this. going to reset mines tomorrow. I've got about 1700 miles on her
Old Mar 29, 2009 | 08:09 PM
  #38
albert101's Avatar
W204 C280
Will there be a sound or a beep or anything to indicate that it has been reset already?
Old Mar 29, 2009 | 10:19 PM
  #39
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Holy thread revival batman!
Unfortunately no audible/visual indication when I've done it. In my experience the few times I've done it, I've been able to tell that the transmission feels a little more aggressive afterward. Probably because it adjusts to my daily driving which is less aggressive. Darn kids...
Old Mar 29, 2009 | 10:48 PM
  #40
RLE's Avatar
RLE
Reset which computer, pray tell?
Originally Posted by ohlord
the tcu not the ecu.
procedure as above,make sure key is just to on (not run) some nimrod did that and wondered why his engine hit the rev limiter in park
resets trans to factory shift points,will relearn to your driving style so repeat as directed
ohlord
I have relearned the trans in my old 5-speed '01 C320 and it is a defined procedure that takes a while. I have no idea whether the 7-speed is relearned the same way or for that matter whether it can even be done.
It does not involve any manipulations of the ignition switch.
Old Mar 30, 2009 | 12:06 AM
  #41
aprince2die4's Avatar
08-C350 black/black
no sound or beeps....but from a before and after i could tell the shift points had moved from 3500rpms to 4500...feeling more aggressive...or maybe it was just my foot pushing down on the pedal harder...
Old Mar 30, 2009 | 10:50 PM
  #42
RLE's Avatar
RLE
OMIGOSH
Originally Posted by AsianML
Even though your car is a manual, it is still drive-by-wire so it should work. Try it out.
The throttle is electronic. The manual transmission is purely mechanical. With that answer, you lost MANY points.
Old Apr 24, 2009 | 12:10 AM
  #43
kim sol's Avatar
W204 C200K AV
Old Apr 24, 2009 | 04:33 AM
  #44
CrAZyVeGAsBoY's Avatar
C300 4matic Sport, CBR 954
Because it's been covered ad infinitum all over this site.
this is true but the time u spent spaming him you just answered it
Old Apr 24, 2009 | 05:48 AM
  #45
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
drive-by-wire means the throttle is controlled electronically. you lost more points with THAT response.
Old Apr 24, 2009 | 08:10 AM
  #46
AMGTTV8's Avatar
2026 AMG GT63 Pro
One of the more ridiculous things I've read online recently
Old Apr 24, 2009 | 11:40 PM
  #47
RLE's Avatar
RLE
Throttle
So you believe the manual trans can be retrained, then?
Actually, the throttle is under your foot and through a controller sends a variable signal to the engine management system, resulting in increased fuel flow to increase RPM, vary ignition timing plus sends signals to the transmission control module if it's an automatic.
Happy now, Frankie?
Old Apr 25, 2009 | 12:44 PM
  #48
woofwoofz's Avatar
2009 C300 4Matic Sport...2012 C350 4Matic
I am @ 1500km now. Should I wait longer before the ECU recet?
-DW
Old Apr 25, 2009 | 02:43 PM
  #49
AsianML's Avatar
2007 E63
Happy now, Frankie?
Having the transmission retrained isn't the only reason the reset is performed. The other half is to lessen the drive-by-wire lag. That would be the only reason manual transmission MB owners would do it for.
Old Oct 13, 2010 | 03:01 AM
  #50
delirium's Avatar
C350
I tried the ECU reset by stomp pedal method and I think its a mental thing. I didnt really notice any difference, however I was more apt to step on the accelerator harder in order to have the ECU learn a more aggressive driving style... so i was driving faster, but the car behavior was the same as pre "reset"
