Buldge in the side wall
Old Mar 21, 2008 | 01:39 AM
hans99201's Avatar
C350
Hey guys, while I was driving today I wasnt paying attention and hit the curb. My front right tire has a huge buldge in it. I was searching for the same tire and found a different michelin tire then what was on the car. Would it matter driving wise/wear and tare, if i had a different brand tire on my front right side of the car.
Old Mar 21, 2008 | 02:25 AM
got_thang?'s Avatar
2008 C350
It all depends you might feel a slight pull but that's in the worst case I might check alignment on it too. I don't know
Old Mar 21, 2008 | 09:14 AM
Derspeed's Avatar
X3 and 2012 C coming soon
It's probably not a good idea unless you replace both front tires with that brand. Then, when the rears wear out, you can replace them with the same.
Get Pirelli PZero Nero M+S. I've had them and have found they are less expensive than Mich.(which suck a$$), Contis., and Goodyears. They perform very well and are the quietest tires I've ever owned. They also last 30,000 miles. I am not sure why they cost so much less than the competiton.
Old Mar 21, 2008 | 09:36 AM
aowhaus's Avatar
2008 C300 Sport 4matic
sidewall blisters are not good, it would need to be replaced as it could pop open (think of it as a large zit).
I had a sidewall blister on my other car and had it inspected and I was told it needs to be replaced from a reputable tire center.
Old Mar 21, 2008 | 11:36 AM
ShoremNJ's Avatar
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
Don't do it, stay with the same tir. Severe braking would make a big difference with grip of each tire.
Old Mar 21, 2008 | 02:36 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Hmm... my understanding is that it shouldn't matter too much as long as the tread pattern is similar?
But yes, that tire definitely needs to be replaced. You don't want that thing suddenly blowing up on the highway.
Old Mar 21, 2008 | 02:52 PM
benggolf's Avatar
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
The buldge on the sidewall indicates the tire has been damaged and continued use will compromise your safety. It can blow out anytime and you may lose control depending on the speed and road condition when it happens.
Replace it with the same brand and size only as doing otherwise will cause handling problems during heavy braking and/or adverse road conditions.
Don't put your safety and others at risk. Go to your MB dealership if you can't find the tire you need at your local tire shop.
Old Mar 22, 2008 | 09:29 AM
thatonealex's Avatar
C220 CDI W204
Why dont you just got see a professional?
Old Mar 22, 2008 | 09:36 AM
Saks_C350_Sport's Avatar
CLS63
Not sure which setup you have but I needed a tire on my car and the only place the tire is available is MB. My opinion is to replace the one tire with an original stock tire. Good Luck.
Old Mar 22, 2008 | 07:32 PM
narky's Avatar
2008 Arctic White C300 Sport 6M
I've always been told by car tech guys, garage shop guys, tire shop guys, and friends that tires should always be replaced in pairs (left/right) at the least. The best solution, of course, is to replace all four corners at once to ensure that they all have similar tread wear.
Replacing just one tire may or may not have a noticeable effect on your car's performance. But why take that chance? Is $100~300 (whatever brand you get) more for one more tire really that much more? It's your life!
At the minimum, change both fronts (or rears, wherever the bulge is).
Old Mar 22, 2008 | 11:29 PM
slammer111's Avatar
^ Generally you are correct, it does depend. Last year I drove over something that tore the sidewall on one of my tires I ended up buying a used tire (same brand, same size) with a similar tread pattern.
I can see a problem if you have 1 new tire on the same axle as a used one (even the rolling diameters will be different), but imo that needs to be judged on a case-by-case scenario.
Old Mar 23, 2008 | 05:21 AM
narky's Avatar
^ You are 100% right, of course.
But as for me, I'd rather not take ANY chances. As I've said, we've only got one life each.
