Old Jun 16, 2015, 04:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting Guides
Print Wikipost
Front dome lights
Old May 26, 2008 | 08:54 PM
nolabenz's Avatar
c300 sport
Front dome lights
Can some one give me instruction on how to change the front dome light bulbs?
Old May 27, 2008 | 01:34 AM
narky's Avatar
2008 Arctic White C300 Sport 6M
Don't know how, haven't done it, but hopefully the following helps:
https://mbworld.org/forums/showpost....4&postcount=18
It's RLE's instructions on how to hardwire a Valentine V1, but it also includes instructions on how to remove the dome light unit. I'm sure you can figure it out from there.
Good luck, and while you do it, please do take lots of pics and post a DIY. You'll be the first, as far as I know.
Old May 27, 2008 | 04:25 AM
The Mercster's Avatar
C320 CDI Elegance
nolabenz, looks like you are replacing all of your interior wedge bulbs. Have you managed to change those for the vanity mirrors and those in the footwells? If so, can you please share how you removed the covers. Thanks.
Old May 27, 2008 | 09:18 AM
nolabenz's Avatar
c300 sport
I was only able to change out the rear map lights and trunk light. I'm having difficulty taking the cover off of the front dome light. I will keep you updated.
Old May 27, 2008 | 10:08 AM
C320 CDI Elegance
I found changing the trunk one quite easy. I juts opened the flap which is on the side panel near to the lamp - put my hands in there and felt for the bulb. Once found, I pulled the bulb out and pushed in the replacement. Did it all blind, as it's all behind the side panel.
Old May 27, 2008 | 10:59 AM
got_thang?'s Avatar
2008 C350
Just use a flat tip screwdriver with a microfiber towel over it and ply it out. Just be gentle, works for me
Old May 27, 2008 | 11:03 AM
C320 CDI Elegance
Thanks. I'll give it a try.
Why do you need a microfibre towel? To prevent possible scratching or something more technical?
