When Getting Rims
Old Jun 7, 2008 | 01:46 PM
UR2SLO's Avatar
ML
When Getting Rims
Hey Guyz,
I was looking to purchase some rims for my c300. But I found out there is not much choice for 17" (didn't want to change my summers). My question is when you guyz purchased your rims did you buy new sensors. There are about $120 here in Canada from the dealer. (please post if you find anywhere online cheaper. So my deal is go higher than 17" and use my current summers for winter. State your opinion
Thanx
Old Jun 7, 2008 | 06:07 PM
c350blknav's Avatar
08 C350 fully loaded
I swapped my sensors, But if you want to have two sets of rims you probably will wan't to have two sets of sensors in order to avoid having to take your tires all the tires of the rims and re-mount and balance 8 sets of wheels each time you do a switch. That can be annoying. Whereas if you have 8 totol individual sensors you can do the switch in your garage. All you need is the wheel lock key, a jack and a tire iron.
Old Jun 8, 2008 | 01:12 AM
qlaval's Avatar
B200T 2007, C300 4MATIC 2009
If I'm right Canadian C model don't have TPMS sensors.
The C in Canada only check the speed rotation of each wheel to determine if one wheel rotate faster.
Old Jun 8, 2008 | 01:53 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
Whats with the ""? In fact we do have some sort of pressure monitoring system as I looked in my wheel's yesterday and saw 2 or 3 square indents on each rim.? I'll try to take a pic tomorrow but I think it's MB canada's version of the TPMS.
Old Jun 8, 2008 | 02:08 AM
radiance's Avatar
C300 4Matic
hey, I'm pretty sure the Canadian version C class does have the pressure monitoring system. On the dashboard computer there is a menu for tire pressure monitoring system!
Old Jun 8, 2008 | 02:23 AM
Savage c-300's Avatar
C300 Sport, MM, P1
Originally Posted by UR2SLO
Hey Guyz,
Thanx
I had them take the sensors out of my old rims and stuck them in the new ones. I dont plan on switching out rims like you guys do because i live in S. Cali. I think tirerack.com sells the sensors, have you tried checking there for pricing?
Old Jun 8, 2008 | 02:58 AM
qlaval's Avatar
The means if if I remember well...
Nothing related about your or others comments.
But yes I do remember now...
https://mbworld.org/forums/c-class-w204/220311-can-i-ask-canada-c350-4matic-have-not-tire-pressure-sensor-right.html
https://mbworld.org/forums/c-class-w204/230993-tpms-curious-question.html
Old Jun 8, 2008 | 03:01 AM
qlaval's Avatar
Originally Posted by radiance
hey, I'm pretty sure the Canadian version C class does have the pressure monitoring system...
I didn't say there weren't any, I just said it didn't use TPMS...
Old Jun 8, 2008 | 03:06 AM
Nothing related about you comment.
https://mbworld.org/forums/showthread.php?t=220311
https://mbworld.org/forums/showthread.php?t=230993
I'll take a pic of my sensors tomorrow morning and post them up. I think their sensors, they look like 3 square indents on the inside of the wheel rim with some writing on it.
Old Jun 8, 2008 | 03:18 AM
qlaval's Avatar
TPMS sensors are located inside the rims.
They look like that:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=320260930146
I own a B200T and it also have an indirect tire monitoring system I suspect the Canadian C to have the same system.
I own a B200T and it also have a passive tire monitoring system I suspect the Canadian C to have the same system.
Ahh ok, so it must be some other type of sensor. Maybe those sensors are the passive tire monitoring?
Old Jun 8, 2008 | 03:19 AM
qlaval's Avatar
... they look like 3 square indents on the inside of the wheel rim with some writing on it.
I think those are the small weight they glue to the rim to balance the wheel...
Old Jun 8, 2008 | 03:21 AM
ahh yes possibly.
Old Jun 8, 2008 | 03:23 AM
qlaval's Avatar
Like those...
http://www.traxjh.com/adhesive.html
Old Jun 8, 2008 | 03:25 AM
Bingo! My bad
Old Jun 8, 2008 | 03:29 AM
qlaval's Avatar
Read the following: It explain how it works...
http://www.tirerack.com/tires/tirete....jsp?techid=44
Canadian C use an Indirect Monitoring System.
Old Jun 8, 2008 | 04:01 AM
c350blknav's Avatar
I bet it has to do with the weather being so cold... Maybe the pressure is allways going to be too low and sensors will allways be RED in your DASH LOL!!! Sorry had to say it!
