SIDE MARKERS NOW AVAILABLE!! CLEAR & SMOKE!!!
#76
2014 Ghibli S Q4 & 2008 C350
Could you post a couple close up pictures? I'm sure a lot of us here are eager to see the smoked installed on a dark car. Thanks!!!
#78
I just ordered mine smoked on my black.. I didn't even think about the silver seam cause I decided that yes, no matter how it is, its gonna be better then the stock yellow. About the seam? If it looks really bad, I believed it would be easily customize by myself or anybody. Lol yeah Stickyz, it would be nice to check out ur ride man!
#79
there is not a silver seam on the smoked. look at mines real close the plastic is alittle frosted on the edges nothing to get all worked up about they look good can't wait to put them on the car
#81
sorry, crap camera...these are the smoked. as you can clearly see there is a stroke around outside that is lighter or not clear. if that area was black or perfectly clear the side marker would appear smaller and look better. hope these help/
#82
15 Mercedes C400, 12 Mercedes C250 coupe
I like it!
can u take a shot of ur entire car? like a 3/4 shot just wanna see how it looks...
#89
I just got my smoked ones today. I'm havin a crap of a time trying to get the OE Side markers off.
Someone let me know if i'm doing this correctly..
Do I need to unscrew the screw in the back of the OE markers? Seems to be a housing holding it in.
Sorry as I just attempted to install them and its about 1am and I have no flashlight lol. I'll give it a shot tomorrow at work.
#90
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
#92
I'm assuming you were able to get to the back of the assembly through the wheel well. Once you unscrew the light bulb, there's this tab thing on the upper middle of the assembly. This attaches the unit to the housing. Press down on the tab and keep wiggling it around. This is tough because it won't come out unless things get aligned just right, so just keep wiggling and twisting it around till it pops off. No screws needed.
BTW, I also notice that no matter how hard I tried, the is a small "opening" along the lower rear corner of the clear marker? normal?
#94
Just recieved a set!!! looks awesome
hello newbie here...just ordered from the ebay seller with derspeed's car on it....the corners are very nice....didnt notice ne glue risidue..very clear and clean lenses...quik question tho it came with a black rear housing that can be clipped off when i recieved it(both pieces)...can neone tell me wut this is for and do i need it on when i install the lights...thanks in advance and will post picks when i get them on....oh yea and i have the c350 black on black
#95
Well putting the new clear ones in is a tough job for me, I just installed them and it drove me nuts trying to hook them in from outside the bumper into the holes on the housing inside the bumper...
Yeah, all the instructions have been how to disassemble, but not install. It took me a while to get it down. There might be better methods, but this is what I did. Don't align the black housing of the unit flat against the inside of the fender. That's how it'll eventually be, but you need to first angle the bottom so that it's almost sticking out of the fender. This will give you an easy access to the place where you're supposed to hook in the sidemarker unit. Once you have the two hooks secure, twist the housing unit slowly back to a vertical position so that it'll be flat against the back fender. This will also pull the unit in with it as it's attached by the hooks. make sure that the bottom of the unit's nook thingy are inside the fender as you slide the bottom part of the unit inside. Try to get the "tube" part of the unit to line up with the housing tube hole on the top middle. Once it's aligned, you should be able to fully close both units together with the main clip. If you did it right with all clips in place, it should fit tightly and securely on with no wiggle and no hole openings.
That's the best way I have to explain it
#96
#97
Hey guys ...
I got my clears on and they look greeeatttt !! I get a manicure and pedicure every week so there was no way i was gonna ruin my nails on this DYI so i got one of my guy "friends" to pop them on half hour and a 6 pack later they were installed and well worth the $$ !!!! I know there are tons of people waiting for these so both this guy and derspeed's contact are gonna make a killinggg !
#99
thats what i was tryin to figure out...thanx AZN C300
