Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Access COMAND Secret Menu
Step by step instructions for do-it-yourself repairs
w204 secrets thread...
#577
3) hold alarm on/off pointed at small square on driver's-side door handle to open/close sunroof and windows.
Can someone explain this? I didn't get it.
what alarm? the lock button on the key?
#578
Vivid Racing '09 C63 AMG
It's the lock or unlock buttons. Hold it down and have the end of the key fob pointed at the square on the handle and it'll open and close all of the windows until you release the button.
#581
It isn't IN the glove box. It's the panel that faces the passenger-side door. When you open that door, you see an interior-color-matched panel. Pull that away and you can access the hidden AUX input.
#585
Hi, i have a C 250 2010 Cdi with front led lights, Pack amg. Portuguese Version.
The tunnel feature Works fine.
The reverse mirror i cant put it To work ((
#586
any interest in one of these? i know there are some things that our dealers didn't explain to us that i had to learn after the fact. it might be a good idea to have a running thread as we figure things out...
1) aux input in glove compartment.
1a) if you have ipod integration, the aux input is tucked away under the plastic cover.
2) aux input is accessed from cd menu (in my non-multimedia pkg).
4) power source in glove box is 12v switched (i remember there was some discussion about that).
5) if you have the automatic tranny, push the stick to the left and hold it there, it'll downshift to the gear lowest possible to allow you to be in the powerband to pass cars. And pushing the stick to the right side and hold it there will put you back into the normal automatic shifting mode.
6) Little arrow on the fuel gauge points to the side of the car that the fuel filler is on.
7) there is a way to reset your service indicators and other lighting options by pressing the OK and TALK button I believe.
8) badges in back leave no holes except for the star.
9) A slight tap of up or down on the turn signal tree allows the turn signal to flash 3-4 times for a lane change and then shuts off automatically. No need to full engage the turn signal and shut it off manually.
10) Steps to Reset the TCU. Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset.
11) brake rotors stay at peak efficiency from feathering initiated after a certain number of windshield wipes during rain.
12) headlamp cleaners activate every 10 windshield washes.
13) when the sun / Pano roof is left open on an extremely hot sunny day, the
car will automatically close it (tilt position) after a while ( when the car is
parked) (euro p2 version only)
14) again if the car is equipped with Sun/Pano roof as well as rain sensing
wipers, the car will again close (tilt position) the roof as soon as the sensors
detect rain ( when the car is parked ) (possible euro p2 only)
15) PRE-SAFE system, which automatically closes open windows, sunroof, and move the seats, headrest + steering wheel to a more protective position - all done within milliseconds as soon as the car senses that an accident is imminent. This is the 2nd stage of pro-safe. First stage is the passive pre-emptive measure, like ESP etc. The 3rd stage is post an accident, which includes automatice shut down of engine and cutting off fuel supply + turning on hazards lights + lowering windows slightly + unlocking all doors.
16) rollbackassist : if i am on steep hills, i notice a roll back assist engages. I think it might happen if i press down on the brakes a bit harder. Release and the car holds itself for a few seconds before rolling back. Works Great!
17) autosense wipers that actually work!
18) on the cruise control stalk: If you push the stalk all the way up, it will increase the speed to the next 5mph increment (ie 52 goes to 55). If you push it down it will decrease the speed to the next 5mph increment (ie 58 goes to 55).
19) this is not somthing you can controll but the new W204 also has vents behind the rear wheels that exit out of the tail lights to keep them clean but more inportantly helps to give the car an overall drag coeffienecy of ONLY .29
20) with the MM the stereos volume will raise if you enter an area with loud noise.
21) If you have the transmission in C, and you punch off the line hard, it uses 1st gear, not second.
22) Leave your headlights in Auto mode & the parking lights & fogs will remain lit when you arm or disarm your car when it is dark.
23) Little arrow on the fuel gauge points to the side of the car that the fuel filler is on.
24) While listening to a cd, the music register or satelite radio, we all know that sometimes you can't read the full title of the song playing. Just press the # button on the dash and you will see the full title and the artist.
25) * key will allow you to jump to a specific track or radio station
26) If you have previously engaged your cruise control at lets say 70mph and are off cruse control but want to reset it to your current speed, raise the cruise control lever to the up position. This will reset it to your current speed where if you pulled the lever towards you, you'll be returned to the previous set speed.
27) slight tap on blinker gives a short 3 blinks for lane changes
28) if you use two fingers you can do all fore windows at the same time, up or down.
29) when the trunk is up and you're still in the driver's seat, you can see out the back, through the center mirror. The hinge lifts up and away, letting you see oncoming traffic before you open the door.
30) Auto dimming mirrors get light when in reverse.
31) dial mounted on the center console will not allow you to change stations or functions display unit unless the hood is raised.
32) In autos, u dont have to turn the ignition key all the way to start the vehicle. in other words, car can start before u complete the turn of the key. Also the car won’t let you re-try the ignition if the car is already on.
33) hood can be pushed up to 90 degrees while open
34) Discovered this feature yesterday. I had the wipers on permanent, not auto intermittent. When I stopped at a traffic light, rather than continuing on wiping permanently, it went into auto intermitent mode by itself. Then as soon as I started driving again, it reverted back to permanent wiping.
35) Wipers, will auto stop when the car stops, then resume when you start driving, with an occasional wipe as needed. This functions works in any mode you have your wipers on. It is dependent on how much it is raining. If it is raining alot dont expect them to stop.
36) Also when you are going down hill with your foot off the gas or on the brake, the car will shift down the tranny so you will have more controll and power to the wheels if you need it.
37) you only get the beep beep beep on the alarm if you actually have an alarm. otherwise just lights will flash.
38) tilt down mirror won't tilt down if you're backing up quickly
39) tunnel mode is available on the 2009 w204 (hold down air-recirculation button)
40) trunk has emergency release on the inside that stays lit for 60 minutes after closing.
keep it going?
keep it going?
Can you please explain #19 below, how does this work?
#587
Think a much smaller version of the vacuum behind a semi, or the still air behind a wall when the wind is blowing.
The vents take air from the wheel wells and vent it out of the taillights, reducing the 'vacuum' and reducing air resistance.
Kind of like cutting a hole in the wall.
#588
Behind the truck of the car there's a low pressure area. A slight vacuum, if you will.
Now that's cool!
Thanks PilotAlan
#589
New one, at least for me.
The fuel filler door locks when the doors are locked. The tab that sticks out of the door is engaged by a lock inside the fender.
I always thought it was weird that the filler door didn't lock (and there's no release inside) so I assumed it didn't lock.
Once I pulled to the pumps, locked the doors and went in to the store, and came out to fill, and couldn't get the filler open. I thought it was damaged and stuck, and finally thought to hit the remote.
Duh.
The Jaguar is the same. I always thought Mercedes and Jag had cheaped out and removed the filler lock.
Duh.
#591
2018 C300 sedan, P1, Multimedia, Burmester
Duh.
Duh.
#592
When you open the filler door and lock the car, you can't shut the filler door until you unlock the car again. I found this out when I couldn't get my filler door to shut after pumping gas, having just locked the car while I was refueling because I decided to go into the gas station and grab a soda! Weird oversight by MB.
#593
This doesn't require that you leave your vehicle while you're re-fueling (which I definitely did not do and do not condone), it simply means that your fuel filler door cannot be shut if the vehicle is locked.
#594
I understand the literal complaint, but the scenario is that if you stay with your vehicle (don't get the soda while refueling, but after the hose is withdrawn and fuel filler door closed), there is no need to lock the vehicle while the fuel door is open. So, the ability to close the fuel door on a locked vehicle is not viewed as necessary, as the attended vehicle should not require locking while the fuel door is open. There is a certain logic to it which may be pleasing or not...but, just responding that it is not an oversight.
#595
Yes, it's part of the Adaptive Brakes on the W204, check this brochure and look at the Adaptive Brakes:
http://www.mbusa.com/vcm/MB/DigitalA...edan-Coupe.pdf
#596
Anyway, thanks for your responses SportStick! You provide some seriously great feedback on just about all of the threads I read on this site.
#597
08 c300 sport 4matic
this is such a great thread. the best secret thus far was the hidden aux behind the plastic panel if you already have the ipod integration kit.
i tried going through all the pages here, but didn't find the answer.
can someone explain to me the hard brake beeping noise? i have an 08 4matic sports. today i pressed on the brake harder than normally before the light, and i heard beeping sounds. I thought it was the hold feature i read about, but it didn't hold the car in place at all. what exactly does it do? thanks!
#598
Noticed an interesting little feature while driving my 09 C230-W204.
When you turn on your heated seats to full, as the temp increases and the seats heat up the system will automatically lower the heated seat setting (initially started at "3", then it went down to "2", and eventually "1" all on it's own).
This was a neat little surprise. This car is TOO COOL!!
#600
2008 mercedes-benz c300 4matic sport
one more thing : for bi xenon package , low beam is xenon , highbeam is halogen only ..so actually its not bi-xenon as MB quoted ...., bi-xenon should looks like on E class , when you flash highbeam ..oncoming traffic from opposite site will be f**ked up with their visions...cant see nothing instead of 2 brightest dots like summer sunshine...
Take 2 thick cardboard or something, cover up the halogen high beam and flash your high beam to see that the bi-xenon is actually functioning. So instead of having 2 high beams you have 4 if you have the bi-xenon package.
