How to take the rear bumper off?
You will need
- 10 mm sockets and some extensions
- torx 25 screwdriver
- screwdriver
- pliers
Remove a 10 mm nut that is holding the wheel well at the bottom
then 2 push pins along the wheel well
then a 10 mm bolt on bumper
remove 2 torx 25 scrws at bottom of bumper
2 10 mm bolt on rear apron
2 torx 25 screws on other side
10 mm nut on wheel well on other side
2 push pins on other side
10 mm bolt on other side
then pull bumper off
- screwdriver
- pliers
