license plate lights
08-C350 black/black
yess and also does neone know how to remove the covers to the interiors...
Front foot wells
Lower door panel/puddle lights
Front dome lights
Rear map lights
Vanity mirror lights
Glove box
i think they all use the 194 bulbs..
Front foot wells
Front dome lights
Rear map lights
Glove box
i remember there was a thread about this that had picture instructions. try searching for bulb replacements. but basically you have to remove the liner on your trunk to get to the license bulb. to remove the liner you pull out all the black circle tabs. it took me about 10 minutes to get it done.
https://mbworld.org/forums/showthrea...&highlight=led
full of pictures and instructions
Front foot wells you can use flat tip screwdriver if you wanna do it the quick way all you need to do is ply out the lens or you can take a torx 20 or 25 screwdriver unscrew the whole kick panel
I haven't decided that i need to change my door panels
Rear map lights just use a screw driver and a soft microfiber towel and ply the whole thing out. ply from the back not the front!
Mirror lights like the foot wells you can just ply the lens out
Haven't decide to do the glove box so iono should be easy as the kick panel or mirror lights
front map lights just use a micro fiber and towel and ply out lens just be very careful cause the can break
