C300 Bolt Pattern?
Old Jul 3, 2008 | 05:48 PM
ronmeister's Avatar
Black 2008 C300 Sport Loaded + Silver 2005 WRX STi Cobb Stage 4
C300 Bolt Pattern?
Hey everyone, my baby is begging for some new shoes.
I need to know what the bolt pattern is on the C300 Sport.
Also, do you guys suppose 19s would be too big?
I was going to go with 18s most likely though, what offset should I be looking for on either size?
Thanks,
Ron
Old Jul 3, 2008 | 05:59 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Both of these have been discussed. Bolt pattern and offset have been shown in PDFs. 19" wheels have also been looked at by several members. In the end what matters most is ACTUALLY your preferences when compared to others. GL.
Old Jul 3, 2008 | 06:02 PM
mb_horseshoe's Avatar
2008 C300 Sport
19's
Old Jul 3, 2008 | 06:43 PM
trial0r's Avatar
black c300 sport p1
5x112 i believe
offset is 45-55
Old Jul 3, 2008 | 06:57 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Originally Posted by trial0r
5x120 i believe
offset is 45-55
BMW bolt pattern
misinformation verboten
Old Jul 3, 2008 | 07:04 PM
trial0r's Avatar
black c300 sport p1
Originally Posted by amdeutsch
BMW bolt pattern
i edited up there...bolt pattern is 5x112
Old Jul 3, 2008 | 07:46 PM
Derspeed's Avatar
X3 and 2012 C coming soon
5x112
The optional 18" AMG offsets:
Front offset is 50mm
Rear offset is 54mm
Old Jul 3, 2008 | 07:49 PM
Shake's Avatar
IS300
5x112... 18" is too small if you plan on getting aftermarket rims. Go at least 19" or just stick with your stock rims.
Old Jul 3, 2008 | 10:28 PM
Derspeed's Avatar
Yeah. Love that wagon wheel look. They might weigh as much too.
Old Jul 3, 2008 | 11:53 PM
ronmeister's Avatar
Well then, 20s @ 5X112 it is!
Thanks a bunch buys.
Ron
Old Aug 11, 2017 | 10:57 AM
Ignacio Agosto's Avatar
C 300
BMW bolt pattern
would 5x100 fit a c 300
Old Aug 11, 2017 | 04:34 PM
Alfadude's Avatar
2012 C300 4Matic
No, the pattern is 5 x 112 like what is written in the posts.
Old Sep 19, 2017 | 08:23 AM
C 300
Bolt pattern
I have a 2011 C300 now when they say offset that means that the rim sizes different from the front and the back and the bolt pattern is 5 x 112 this correct
Old Sep 19, 2017 | 11:38 AM
Alfadude's Avatar
2012 C300 4Matic
No, that is not correct. Offset is the way the wheel is mounted in relation to the hub. If it is mounted in the center with half the wheel being towards the outside of the car and half the wheel being towards the inside of the car, it is zero Offset.
Greater distance from the mounting point to the outside of the wheel is negative offset.More distance from the mounting point to the inside of the wheel is positive offset Here is a link that explains it: http://www.wheelpros.com/page/offset-explained/9
What you asked about is a staggered set up where the front wheels would be one width and the rear wheels would be another width, but the diameter of the wheels would still be the same. Like if you wanted a wider tire on the rear.
