Door Lock Pins Again
A 204 727 05 599 051 (left-in stock)
A 204 727 06 599 051 (right- had to be ordered from Germany)
Pics of polished aluminum pins
Mine look the same and came from the same seller. I'll take pics when I get home I am using the supplied surrounds and not the OEM which would make a difference. Anyone change the rears yet, if so what did you use? Gorilla glue or epoxy? And did they sit flush or did they need to be shimed or drilled deeper?
No if I can only get 1 passenger side the oem surround this will be a done deal.
Thanks AkaSigFreak for the partnumber i will call my dealership tomorrow and see if they can order me one.
BTW, these chrome pins are very nice. Nice metallic heavy pins fit very well with my interior.
Here is pic of the batmobile. Its a lux 300 with sports grille.
https://mbworld.org/forums/attachmen...2&d=1192640789
1 Post
2013 C300 Sport Black Darth V3.0
Well here are the pics anyway
![](http://i2.photobucket.com/albums/y42/Ron_Jr/C300/DSC_5721.jpg)
![](http://i2.photobucket.com/albums/y42/Ron_Jr/C300/DSC_5720.jpg)
![](http://i2.photobucket.com/albums/y42/Ron_Jr/C300/DSC_5719.jpg)
![](http://i2.photobucket.com/albums/y42/Ron_Jr/C300/DSC_5718.jpg)
![](http://i2.photobucket.com/albums/y42/Ron_Jr/C300/DSC_5717.jpg)
As you can see they sit nicely in the ring and from the outside the ring sits flush but from the inside the gap is quite evident. Now my Wife Daughter and Best Friend did not notice the gap ( wife didn't even notice the new pins) but it does bother me. I wonder if the OEM metalic surrounds will work?
#32
1 Post
2008 Mercedes C300 4Matic
They don't make OEM metallic surrounds as was noted earlier today a couple posts up:
https://mbworld.org/forums/showpost....7&postcount=28
#34
Mercedes Benz C300 4matic MM
Carbon Fiber???
Just found these ones on ebay if anyone is interested.
http://cgi.ebay.ca/AMG-CARBON-DOOR-P...ayphotohosting
#35
1 Post
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#37
NO! The part numbers are for the PLASTIC OEM surrounds. MERCEDES-BENZ DOES NOT MAKE METAL SURROUNDS. My pics show the aluminum surrounds from formymercedes.com . They are essentially the same as your surrounds except made from aluminum. Mine sit closer to the door because I GENTLY tapped them with a rubber mallet.
#38
1 Post
OK. If the pins are out mine will sit flush it appears to be the pins that push them out. I'm thinking of cutting a slit in one to see if it will sit right.
#39
Thanks again!
#41
B200T 2007, C300 4MATIC 2009
#42
Ditto. Unless you remove the door panel and release the clips from underneath- it is somewhat difficult to remove the oem surrounds and the tops are very flexible and warp easily.
#44
#45
Ok, everyone is trying to get metal pin replacements, etc. Has anyone considered or managed to get the old fashioned golf tee pins? I really miss those as I consider it iconic for a mercedes to have them...
- Eric
- Eric
#46
Abort! Abort! .. my previous info was inaccurate. The pins do fit very nicely. My driver side lock need more force for the pins to go on properly for some reason. I tried the passenger side and they went right in nice and flush. So then came back to the driver side with a plier with rubber grips on them and was able to easily screw it all the way in.
Today was a nice day. I did some work on the car. First washed, then waxed.Changed the grill from sport to lux (I have both) Then took care of the door lock pins. Finally got to installing the oem surround and the chrome pins. Everything looks great now. I am one satisfied customer. Also posted some pics. Also posted the grill pics in another thread. Just do a search for "wildcard011"
Here are some pics after the install.
