Quote:
Originally Posted by teamplayer
What happened to pics? I don't see any pics?
You dont need any pictures to do this.
Quote:
I want to lose metal clips or break anything.... Anyone please repost the pics?Originally Posted by vic viper
I can't see the pics either .....
Don't mess with the clip in the back.It holds down the other part of the filter compartment { a tube like thing } to the engine.
Thanks for the post.Changed my oil already , now I just did the engine air filters on my 2009 C300.
I'll be attacking the compartment air filter next.
Quote:
Originally Posted by Joearch
I watched a tech do this to may car on Monday and he also had to release a metal clip on the backside of the cover against the firewall that held the cover down over the round air intake firmly. My car is a 2020 C300 which is maybe diff than yours.
Quote:
1) All covers attached and as motor looks when hood is opened.
2) The smaller front cover(with MB emblem) removed. The cover is attached with simple pressure pins underneath and then clips connecting to the bigger cover. Just pull up on the sides of the small cover or front lip to pop up and off.
3) Parts circled in red(flex intake tubes and breather hose) need to be pulled off from engine cover/intake tubes before removing engine cover.
Then grab each intake tube that is part of cover from underneath(red lines) and pull up with a little bit of force. Don't be shy as nothing will break as shown in the next step.
4) Spring clips on bottom of intake tubes/engine(4 overall) cover are what attaches to engine via metal pads as shown circled in red.
5) Removal is complete and now an exposed engine is available to work on.
6) To re-install make sure TB opening of engine cover pops down and seals against TB of engine and reverse all procedures above.
Sorry, I shut down the site I had the images linked to in my original post. The images are now uploaded to this site.Originally Posted by racetested
This will cover the engine cover removal for a C350. I assume a C300 is no different unless corrected.1) All covers attached and as motor looks when hood is opened.
Love the post but can not see images of the removal of engine cover to change my oil and air filter, do not want to break clips. Please post some pics. with procedure. thanks.
Sorry racetested, pics appealed after i posted. thanks for the pics. thanks sooo much.
ExploreNewbie
Quote:
Nice pictures. thanks..well done and big help. same enine as my 2007 c280Originally Posted by racetested
Quote:
They're showing up on my iMac (10.6.8) and my iPad 2...not sure why you can't see them.Originally Posted by fjd821
what format are these pictures in. I'm using a mac and they don't show up
Can you see these? I just panted it this week with the guidance of one of our forum members.
Really clean work, dude. Masking that star really was the hardest part to this mod! Lol
Hi all.
I have C300 year 2008. I would like to change cabin filter, but I dont know how. Can anyone show me with the picture?
Thank alot
Thank alot
a little situation with this DIY guide
the pictures are not there anymore, can someone fix this
They reposted on the second page. Scroll up. Originally Posted by kHuNkHuNa
a little situation with this DIY guidethe pictures are not there anymore, can someone fix this
Quote:
wow thanks, i feel completely retarded Originally Posted by Domm
My cover is at the paint shop getting done right now. It is super easy to remove the cover. Just pull straight up and disconnect the vacuum line.
Does anyone have a good suggestion to remove oxidization from the control unit that sits in the middle of the engine cover?
I went to put the motor cover back on today and noticed that the metal piece in the middle of the cover area is pretty dirty and will not come clean. I have tried polishing, buffing and a few other things but it still looks terrible.
Anyone have a suggestion? I would replace it if I could but I am sure it costs a lot. I tried to separate it as well and it does not seem to come apart so dipping it in an acid bath is out of the question.
Quote:
Is it possible to pry the star off and install it back when the job is done?Originally Posted by mikonuj
Adi-Benz
close
- Join DateApr 2016
- LocationMilwaukee, WI
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Liked:566 Times in 493 Posts
Since we are reviving old thread, what is possible to carbon fiber wrap in engine bay?
Quote:
I think the high heat will melt it.Originally Posted by Adi-Benz
Quote:
+1Originally Posted by bcvancouver
I second that. You can check for special high heat wrap though maybe?
Quote:
This tutorial might help. You can paint it with black and silver high heat enamel with some shelf liner to create the carbon fibre effectOriginally Posted by Adi-Benz
