*DIY* I've Unleashed a Cyclops!
Old 08-25-2013, 04:56 AM
  #201
nudda's Avatar
2013 C250 Sport (US)
Originally Posted by zionoliver
I can't see the images on this forum page. Is there another page I can get these instructions? I really need this help here.
^^^^ what he said
Old 09-16-2013, 06:50 PM
  #202
kfriedenberger's Avatar
2009 C63 AMG
How to fix synch issues from dirty power
Originally Posted by Cartronics
Your camera should have power all the time to avoid sync issues when switching to reverse. Hopefully you installed a CCD camera and not CMOS. CMOS can not tolerate constant power, and can emit radio waves that create problems. Try disconnecting power to the camera, reset the TPMS and see if the problem is resolved. Your TPMS will hard error and give a constant error if the error buffer builds up from an inability to communicate with a sensor. That hard error will need to be cleared.
I installed a Kenwood CMOS 210 camera weeks ago and decided to wire it into the reverse harness so it didn't have constant power. I was assuming less lifetime with constant power per various threads here. I did have synch issues randomly so I installed this filter device inline: MEAN WELL SKA15A-12. Have had no synch problems since, and my camera powers up seamlessly on Reverse. $20, four simple solder points, and you're off to the races.
Old 09-26-2013, 11:54 AM
  #203
kenju4u's Avatar
2013 C300 4MATIC Sport with P1, Bi-Xenon headlights, Navigation with backup camera, Sport Plus
Cannot see the images on the writeup so this writeup has become useless. Can someone restore the images?
Old 01-03-2014, 11:28 AM
  #204
1stMB300te's Avatar
1992 300TE
Originally Posted by Rick Hunter
Oooohhh... guess what I received in the mail...
Yes... it's the Midcity Engineering MM204VK package that includes a backup camera! Delivery of this item to the West Coast took about a week, and was packed very well.
So I finally had time to do the install this weekend, and I must say... HOW COULD I HAVE GONE WITHOUT THIS??? For the price (and quality), this definitely beats out the Quickpark OEM system.
So before I detail my DIY... here's the specs:
2008 C300 4MATIC with P1, P2, MM Packages. No TeleAid or Sirius subscriptions present @ time of install.
Disclaimer: I'm sharing this DIY in the hopes that there may be more interest in doing your own DIYs. It is definitely a great learning experience, but I am in no way responsible for any consequences (positive or negative) as a result of you reading this DIY thread. If you choose to do this DIY yourself, you are solely responsible for whatever that happens. You have been warned.
Kewl... now onwards!
I found this document online re: removing the Trunk Lid trim:
In colour, it looks like this:
Regarding the Handle Strip (#7 in diagram), there's a couple of other screws that I had to remove before I yanked the sucker off the trunk (and I mean YANKED). I was careful not to scratch the surrounding paint, though...
Thereafter, I followed the Midcity Engineering video very closely (Thanks, Midcity Engineering!!!)
http://www.youtube.com/watch?v=v_5Fkawy-_g
As far as hiding the video cables, I was able to access the Head Unit from underneath the passenger side panel.
After feeding the wire under the passenger side sills through to the back, I proceeded to mount the camera. I had to cut a hole in the Handle Strip, right at the predetermined hole. The plastic's thick, so it was a PITA. I then fed the camera wires down the Trunk Lid and down towards the tail light.
The last thing that needed to be done was to splice the proper wires so that the camera would have power. After spending hours and hours scouring for info, I was able to figure out the right ones.
Brown = Ground
Grey/Yellow = Reverse Light
So... does it work? The moment of truth...
SWEET!!! After putting everything back together, I took some final pics.
-fin-
RICK HUNTER, can you reupload any pics?
Old 08-07-2014, 04:13 AM
  #205
QuartzBlueP31's Avatar
2010 C63 P31
Anyone already have a FAKRA connector on the Command unit when they pulled it out? How did you connect the camera FAKRA?
Old 08-23-2014, 03:11 PM
  #206
balthaser's Avatar
2009 C63 AMG
Anyone can restore the images so that this thread is useful again?
Old 11-20-2014, 09:56 AM
  #207
Lecson's Avatar
W204 C250 CDI 2011
Images ??
Old 05-03-2015, 01:17 PM
  #208
SCTinkering's Avatar
2013 C250 Sport P1
Originally Posted by Lecson
Images ??
I wonder if Flckr changed the url of the pictures but they still look okay to Ray because I don't see them either.
Old 06-11-2015, 10:51 PM
  #209
sudhanshu3's Avatar
c300
Can someone please repost the pictures?
Old 12-16-2015, 10:04 AM
  #210
fl0wmastr's Avatar
c250 Coupe Sport
photos no longer load! please fix!
Old 12-16-2015, 01:55 PM
  #211
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
Just to give you guys an update about the $20 backup camera which has constant power by the #71 fuse. After 4 years now of use and after driven 78k and subject to canadian weather it is still working like a champ.
Old 12-20-2015, 10:27 PM
  #212
ghlkal's Avatar
2012 E550 v8-Biturbo
Wow, that's impressive
Thanks for the update.
Old 10-07-2016, 10:33 AM
  #213
youbecha's Avatar
2015 C300
I don't suppose there is anyway to get a link to the pictures?
Quick Reply: *DIY* I've Unleashed a Cyclops!
