OIil Change question
Old Jul 30, 2008 | 04:51 PM
kevin1446's Avatar
2008 c300
Prior to bringing my 2008 in for the 13,000 mile check, I decided to look under the car and see if I could change the oil myself. I rode the car up on rino ramps and crawled underneath. I removed the cover which was 8 - 10 8 mm screws and it just poped off. I thought I found the oil drain plug but I am not sure. It was facing the passenger front wheel and looked like it had a brass washer on it. Has anyone ever seen the drain plug? I decided to bring to the dealer for service but I am not thrilled with them sucking the oil out the dip stick hole. I had brought it in for an oil change at 6,000 miles and 2 days later brought it back because they overfilled it by 1 quart. I never really believe they can fully remove all the oil the way they do it. The filter is right on top under the engine cover and is very similiar to the 2004 BMW I had. I would also appreciate anyones help is telling me what Mobile 1 extended life oil I need. The oil change, wiper replacement and service indicator reset was $189.00. If I went the full way which is unnecessary it would have been $350.00 It is not the cost but the way they perform the service that bothers me. I have had 4 Lexus's and 1 BMW in recent years have always done my own service. With this car it seems like everything is a secret.
Old Jul 30, 2008 | 05:40 PM
e1000's Avatar
a quarter mile at a time
there was a forum member in the W203 section that did a nice write-up about doing oil changes both ways. He found that both methods effectively drain the same amount of oil out of the car. There are a couple of DIY oil change instructions in the W203 section that will carry over to the W204. If you can come to terms with sucking it out the top, an oil change on the M272 engines is VERY easy to do
Here is a list of approved oils for your MB. http://www.whnet.com/4x4/oil.html
Old Jul 30, 2008 | 07:43 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
do you have pics of it and a step by step i want to do this myself.
Old Jul 30, 2008 | 08:31 PM
joebenz's Avatar
99 DC2, 08 C350
my friend is a mechanic at a MB dealer. he says they change the oil using drain plug at his dealership because they can't tell how much the pump actually sucks out
Old Jul 30, 2008 | 08:40 PM
e1000's Avatar
https://mbworld.org/forums/showthrea...796&highlight=
same engine as W204
Old Jul 31, 2008 | 12:02 AM
hmc's Avatar
hmc
2009 C300 Sport 6MT
Kevin1446:
Please check out messages in this thread: http://www.benzworld.org/forums/w203...2007-c230.html
thread starter used pumper but someone (in the messages) drained oil and described where it is. Can you confirm it's where what you saw?
I would like to know where drain plug is too, ideally in picture.
Old Jul 31, 2008 | 03:12 AM
white_glass_top's Avatar
2008 C300 SPORT (white)
10w-40
mobil also writes on the bottles which makes their oil is for. did oil change myself at 6,000 miles, but didnt no where the filter was at, so i just changed oil, but now i see its under the engine cover, i will be do another this weekend.
Old Jul 31, 2008 | 08:34 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
You know I just checked my oil since the last change an it seemed like it is overfilled. It is over the top of the red indicator on the stick. You brought it back to remove a qt?
RickP
Old Jul 31, 2008 | 10:08 AM
ColoradoDriver's Avatar
2011 E350 Sport 4matic
Originally Posted by white_glass_top
10w-40
My dealer says to use Mobil 1 0W40 that meets MB specs. (Not 10W40)
And here is a quote from the Mobil web site:
Your vehicle has a specific recommendation
The company that manufactures your vehicle recommends this Mobil 1® product, or has a special requirement.
Current Vehicle:
Year: 2008
Make: Mercedes-Benz
Model: C300
Engine Type: 6cyl. 3.0Liter Naturally Aspirated
Mobil 1 0W-40
A fully synthetic motor oil, Mobil 1 0W-40 with SuperSyn Technology exceeds industry standards and the major leading builder requirements, enabling the product to keep performing well after conventional oils cannot. Mobil 1 is recommended by leading car manufacturers as initial fill.
Special Filter Not Required
