aftermarket grille selections
Old 10-27-2008, 09:20 PM
  #176
MBworld Guru
FrankW's Avatar
white and whiter
Originally Posted by syrAMG
the T bar has 2 screws that are attached to the body.
the screw holes on the T bar is oblong so the screws can be in place
at various points. some people probably screwed the T bar down at the far top
heres an example: "( )" represents the hole size; "O" represents screw down point
Center alignment (.......O.......)
Far top towards engine (...........O)
towards grille (O..........)
this maybe the reason why its sticking out
that has very little to do with how the grille fits.
how the grille fits is decided by the bottom row of clips and the two side mount. The top is just there to hold it in place.
Old 10-28-2008, 01:12 AM
  #177
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
(.......O.......)
Somehow that just doesn't look right...
Old 10-28-2008, 07:27 PM
  #178
syrAMG's Avatar
W212 2011 E-350 4Matic
yeah that was the best way I could express that.
before that diagram I tried to make the "T" bar using | \ \ |
and when I tied to express the holes with O O, it just didnt look like a car part....
Old 10-28-2008, 10:30 PM
  #179
kevink2's Avatar
2004 Mazda6, 1993 RX7
Originally Posted by AkaSigFreak
......the top of the grille to stick out past the edge of the hood.
Did you check the bumper tabs, as I said in your other thread?
"Make sure the lower bumper tabs are fully engaged forward. If not, the grill will pivot on the side post supports and protrude at top."
Old 10-29-2008, 03:22 AM
  #180
mikli's Avatar
C200K
hi everyone, I have heard the big star included on the aftermarket grille is not the same as the one on OEM sport grille. Though the star is authentic, it should belong to another MB model and the size is bigger. Can anyone confirm this?
Old 10-29-2008, 04:17 AM
  #181
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I checked the lower tabs. If I push on the grille from behind- I hear it "pop" in but it pops back out about 1/16". Not much but enough to let it move.
Old 10-29-2008, 11:09 AM
  #182
JasonEB's Avatar
C300 4-matic 2008
what point on the "T" bar did you screw the frame down?
I have a feeling many installed it all the way in the back; promoting the front part to stick out.
I screwed my grille at the middle point on the T bar.
I dry fitted the grille by lightly screwing down the "T" bar and closed the hood to see if its aligned properly.
I think if you put back the mounting cover after you screw the T bar, the mounting cover will push the grille to the front, causing the grille to stick out.
So, does the position of the screw on the T bracket matter?
Old 10-29-2008, 07:46 PM
  #183
cvkatigbak's Avatar
C300 MT, 350Z
Originally Posted by FrankW
mine on the right is pushed in more because the hood's misaligned and pushes the grille in on the right.
your hood could be the opposite of mine which pushes the left side in. lol
i had the same problem. i painted my grille black and everytime i closed and opened the hood it would scrape off my paint. i got tired of it so i opened the hood, untightened the three bolts holding the hood on each side and realigned it myself. now the sides are perfect not hitting the grille
Old 10-29-2008, 08:44 PM
  #184
syrAMG's Avatar
Hi there welcome to the forum
the star as mentioned by rb23lb
not the same size... the after market star is less wider on each point of the star...
just found this out after comparison
I barely noticed the difference, until I mounted the star on to the grille it was very loose and can easily come off.
I used the 3M auto tape on the 3 points and the thing is firm and secure then ever.
Old 10-30-2008, 02:47 AM
  #185
mikli's Avatar
C200K
So can I get the aftermarket grille without the star, and affix my star from the OEM sport grille there? Does it fit more snuggly than the supplied star with the aftermarket grille?
In fact what is the part number of that supplied star? If it's slight different from the sport grille star, could it be the real star on the C63 grille?
Old 10-30-2008, 07:57 AM
  #186
E350 Sport/ML350RWD
Definitely NOT. I know it comes in a MB box bot I'm not convinced it is authentic. It is light and has no markings on it. Besides the fact that it mounts by small tabs that lock in place by turning 1/4". If this was OEM- no car would ever have a star on it (everyone would steal them). The OEM mounts by inserting the approx 1" locking tabs in the slots and is heavier with markings on the inside.
Old 10-30-2008, 10:18 AM
  #187
mikli's Avatar
C200K
Oh that means fake star in a MB box (that could be fake too). But what about my idea of replacing it with the OEM sport grille star? Will the real star fit the slot of the aftermarket grille? Has anybody experimented this?
Old 10-30-2008, 03:22 PM
  #188
E350 Sport/ML350RWD
No. The mounting tabs are completely different.
Old 10-30-2008, 05:15 PM
  #189
MBworld Guru
FrankW's Avatar
white and whiter
the star is OEM ML star.
Old 10-30-2008, 11:14 PM
  #190
mikli's Avatar
C200K
Do you mean the "ML" Class?
Old 10-31-2008, 02:09 AM
  #191
MBworld Guru
FrankW's Avatar
white and whiter
yes. it had the 163 part number.
Old 10-31-2008, 01:28 PM
  #192
syrAMG's Avatar
the format of the OEM W204 star is completely different from the aftermarket grille.
I do not see any downside in using the star that came with the grille.
the star looks fine. just look at my pics below.
the only improvement I have done is purchased a 3M auto tape and
taping the 3 points on the star and the center.
now there is no shifts nor loose parts for the center piece.
Old 10-31-2008, 01:52 PM
  #193
mikli's Avatar
C200K
Is the attached photo showing a star (Part#163 for the ML Class) that comes with the W204 aftermarket grille?
http://auction1.taobao.com/auction/i...431c26833e8157
Above is a link to another aftermarket grille for W211 E Class that also uses the same star. Seems all aftermarket grilles have it as a standard.
Old 02-09-2009, 09:07 AM
  #194
hongcl78's Avatar
C200
Bringing up an old thread. Anyone still interested? madracer, do you still organise any purchase on this item? Thanks.
Old 02-09-2009, 06:11 PM
  #195
MBworld Guru
FrankW's Avatar
white and whiter
most of the listed grille are on ebay now.
Old 02-09-2009, 06:38 PM
  #196
TB5...'s Avatar
2009 C300 4Matic
this makes me happy...
Old 02-09-2009, 09:03 PM
  #197
SuperDavid's Avatar
C350 2008
I have one C63 grille style, I can sell for $199 with free shipping for any 48 states and PR. Never use the grille, because I change the front bumper in C350 to C63 bumper and the only grille that fit is the original.
Old 02-09-2009, 10:49 PM
  #198
hongcl78's Avatar
C200
I know. But are they of the same fitment and quality as what madracer offer?
Old 02-09-2009, 10:55 PM
  #199
hongcl78's Avatar
C200
Did you get this off madracer too? Even if not, how is the quality and fitment like? Thanks.
Old 02-16-2009, 08:35 AM
  #200
SuperDavid's Avatar
C350 2008
I get from 55Tech, the quality is similiar to the OEM, I already installed two in my town. The car looks great !!! I compare the new C63 that I installed in C350 with the aftermarket and looks very similar, the MB emblem in the aftermarket is more bigger. If you like the grille, I can send by $199 FREE shipping (US only) or contact me for international shipping.
Quick Reply: aftermarket grille selections
