side marker help
Old Aug 31, 2008 | 04:01 PM
Saks_C350_Sport's Avatar
CLS63
side marker help
my driver's side marker light fell out last night on the highway. I was driving fast on the Interstate toying around with an M3. When I got home and pulled in the garage, the light assy was hanging out by the wires. The internal piece, which seems like it should snap into, is loose inside the bumper cover. Does that internal piece usually float and just sandwich together with the outer assy? Any help would be great. I don't wanna take anything apart this afternoon unless I have to.
BTW........ The C sure is smoooooooth at 140. LOL
Old Aug 31, 2008 | 04:20 PM
maverickvii's Avatar
2008 C300 Sport 6M
The inside piece of the marker does float around on its own until you pop the outside piece into it. So hopefully you should be able to just snap them back together with a little patience.
Old Aug 31, 2008 | 09:49 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
inner piece floats around. the outer piece hooks on the bottom and clip in on the top and then secured by a single t10 screw on the back side.
you'll need to remove 3 push pin along the side of the fender well cover and pull back the cover to access the back.
Old Sep 1, 2008 | 08:01 AM
CLS63
Thanks guys. I was able to open the inner fender well and snap the light back together. No screw in back as far as I could tell. Did mine fall out somehow ???
Old Sep 1, 2008 | 05:04 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
probably. go to your dealer and commence complain.
Old Sep 1, 2008 | 06:27 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
did the spped limiter kick in at 140?
Old Sep 1, 2008 | 06:49 PM
syrAMG's Avatar
W212 2011 E-350 4Matic
that happened to me after a pothole.
I was able to snap the light in.
Old Sep 1, 2008 | 07:00 PM
2008 C300 Sport 6M
When I swapped for clear reflectors there were no screws either and the car was brand new so not so sure that they all have screws...but don't know.
