PCMCIA/Memory Card Question
BMW E90, W204 C350
I load radio into my memory card, but sometimes when i turn on the car again, let say i listen up to 04:10, sometimes the car will start from the beginning, and sometimes it will start from 04:10
anyway to make sure it start at the spot i turn off the car ?
thanks
thanks
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
not really 100% sure what you mean.
What I understand is , when you are using the card to listen to music and you swtich off the car and start it again the track you were listening to starts from the begining? you want it to start from where you left it?
By default, the track should start from where you switched off the car. if its not , then there might be a problem with the track you were listening to or might be a problem with the card you are using.
I am not using the cards so far so wont know for sure.
P.S planning to use the card if I can find the 6-1 PC card reader from Sandisk that supports Sandisk SDHC 4GB or 8GB here in holland.
