W204-I need to know what is the wire color for the power antenna on a non HK system.
Replacing head unit with aftermarket and have installed all wiring except the power antenna wire because I do not know which one it is. The system is non HK so all wiring is from the harness on stock head unit. Thanks.
No power antenna wire in the car so the 2008 C300 is wired up . I recieved an antenna adapter from crutchfield with my CDA-9887 however it looks like I can hookup 3 different wires to the adapter that goes to the alpine. I looked at the back of the factory deck one of the plugs says FM, the other says ohm and the the other is blank. I plugged in the FM and I only got FM reception. I know AM, who cares, but I listen to the Laker games on AM when I am not at home. Is there some type of adapter with two inputs for FM and AM? Thanks.
