19" rubbing
Old Sep 10, 2008 | 07:42 PM
c3nthusiast's Avatar
2008 C300
19" rubbing
My right rear rubs ever so slightly when I hit dips in the road or turning left with people in the car. There is no tire damage. Looks like it hits just enough to scrape the tire dressing off. If I lower the car with progressive rate springs will it rub more?
Old Sep 10, 2008 | 08:12 PM
Alex@wheelexperts's Avatar
07 S550 & 08 335i
Most likely it will rub a little bit, but remember the further down you go, the more your rear will camber in...
Old Sep 10, 2008 | 09:20 PM
2008 C300
That makes sense (camber). I was thinking about a smaller tire on the rear 265/30 down to 245/35.
I had the same set up on my Maxima. F 235/35-19x8.5 and 245/35-19x9.5.
Old Sep 11, 2008 | 12:39 AM
nychokeyplaya35's Avatar
08' C350, Toyota Tundra
Rubbing
You must gotten a wrong offset or something my friend has 20's on his C350 and they dont rub.....
Old Sep 11, 2008 | 12:11 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
You probably need to fold the fenders
Old Sep 11, 2008 | 12:44 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
get tires with rounded sidewalls? Like Toyo T1Rs?
Old Sep 11, 2008 | 03:18 PM
misterng's Avatar
2008 W204
Roll your fenders!
Old Sep 11, 2008 | 05:15 PM
bigigg's Avatar
14' CLS550
i have 20's and they only rub in the front.. my rear i have no problem at all..the dealer is gonna change the offset for me and see what happens.. where on the fender does it rub the outside lip.. or underneath, like the plastic?
Old Sep 12, 2008 | 02:40 AM
lx Raven xl's Avatar
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
Can you please explain what offset means. does it mean the distance between the centre of the rim to the disc it attaches to?.
Also can i have a staggered setup with 17inch rims? All I have to do is buy a wider type for the back? I have non AMG standard wheel.
