where to pour transmission fluid?
is it the plug that says " MB workshop only"? i have a 02 c230 kompressor so here is what im trying to figure out
1) where to pour the transmission fluid
2) is the drain plug a hex key located right behind the drain plug for the oil?
3) how much transmission fluid do i pour in?
p.s i already did a search and i couldent find anything, thanks for reading, please help!
You must determine which type of trans fluid your car requires which is shown in your owners manual. Add nothing until you have this information.
Since you do not know how much fluid was lost, you should drain the trans and start over. The trans drain is on the side of the transmission's pan. If the trans fluid has not been changed in 38000 miles, you should also change the filter which is accessed by removing the pan which must then be reinstalled carefully, torqueing the bolts down properly.
BTW, there is no such thing as lifetime trans fluid which was a bright idea MB had about ten years ago. In 2005 they changed their thinking and made it every 38K miles because there had been too many trans failures due to old fluid.
Fluid is added through the transmission dipstick tube at the rear of the engine which has a cap that must be replaced after each removal since it breaks.
When refilling, add less than the total amount, then drive the car so the fluid is hot since it expands when hot. Check the level with the factory tool (your car doesn't have a dipstick, I suspect and you likely don't have the tool) which requires referring to the sheet (not available to owners) showing levels for your particular engine.
By now you have realized that you cannot check the level without the tool and reference sheet so you will have to approximate and then head to a dealer for a final level check. Driving the car with too little or too much fluid can be costly.
hey ur in the wrong MB class this is W204
