non-ceramic tint and navi
Old Sep 23, 2008 | 11:31 AM
piccirm's Avatar
08 C350 Artic white, MM, PII, 18 AMG, Ipod
Question non-ceramic tint and navi
Will a metallic, non-ceramic tint interfere with the navi, xirius?. Please advise as dealership is suggesting ceramic due to the above.
Old Sep 23, 2008 | 12:31 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
No it won't the antenna is on the roof.
Old Sep 23, 2008 | 12:34 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Not with OEM installed systems. The interference is usually with handhelds or standalone units like my Garmin. I do think ceramic tint has a "cleaner" look though. My tint was perfectly clear the day it was tinted.
Old Sep 23, 2008 | 12:44 PM
maverickvii's Avatar
2008 C300 Sport 6M
I have non-ceramic and nothing has been affected at all (although I can't say I've ever even tried to use AM radio)
Old Sep 23, 2008 | 12:57 PM
tpick23's Avatar
E63
Llumar ATR series
works well for me. No problem with the navigation or the TPMS units and the garage openers work great too.
Old Sep 23, 2008 | 01:59 PM
piccirm's Avatar
Thaks for this info. i'm trying to decide as there is a big difference in price
Old Sep 23, 2008 | 02:57 PM
white46's Avatar
08 C300
dealer wants your money, that's why they are BSing with ceramic / non-ceramic tint.
there is no difference between two as far as radio, cell, navi reception.
Old Sep 23, 2008 | 04:01 PM
Ron Jr's Avatar
Go to a tinter that is not associated with the AD but who has a good rep. Most likely cost you half what the dealer wants. My dealer qouted me $500.00 USD I got it done for 200.00 by an independent shop.
Old Sep 23, 2008 | 06:26 PM
drevil2k2's Avatar
2011 BMW 335xi titanium silver.
I had ceramic tint (35%) - and did not interfere with nav (OEM or windshield mounted), garage door opener or radio. I had the GPS antenna installed against the fusebox and it was fine. Some toll highway transponders might not work, but most people don't tint the front windshield however.
The nature of the ceramic non metallic tint should not conduct or interfere with electronics.
Went to the same place the dealer gets it done and got a good discount. After tinting my last car, it's hard not to tint the new one.
Old Sep 23, 2008 | 07:30 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Just get metallic. You won't notice any interference. Ceramic tint falls in the same category of Nitrogen fill tires.....I'm sure there's a mathematical measurable, but not enough to notice in real world.
Old Sep 23, 2008 | 09:44 PM
piccirm's Avatar
Thanks again guys.
i think I'll go with the non-ceramic. With money saved I may use for other mods.
Thanks AZN, you are in the tinting business right?. I'll then take your authorized word for it.
Regards
Old Sep 23, 2008 | 10:43 PM
peet's Avatar
09 C63
1) ceramic will do better at heat rejection. 2) ceramic will withstand time better and not discolor. 3) ceramic is typically a thicker substrate and will act as a better shatter resistant material. 4) people have had issues with FM and AM signal with non-ceramic films... those antennae are NOT on the roof and are on the rear window. 5) you MAY have issues with GPS antenna as that is inside the dashboard, not on the roof.
So if it's a couple of bucks - spring for it. Probably worth it in the long haul. I unfortunately live in a 50-50 cliamate (hot/cold) so we don't have many ceramic shops. But you coming from NC, you see your share of heat - may well be worth it just for the heat rejection.
Lastly - IF ANY reason... you like using radar detectors? Yep - metallic (non-ceramic) films block that signal. That alone is reason to go ceramic.
Old Sep 23, 2008 | 11:32 PM
Azn_C300's Avatar
Maybe by a few degrees, but like I said, if it's hot, it's hot...100 degrees and 102 degrees in the car feels the same. If you're sensitive enough to be able to tell the difference in 3-4 degrees, then yeah, go for it.
This totally depends on the quality of film. High quality metallic film can last 15 years.
Your vehicle windows already have shatter resistant material on it....this is the wearing two condoms argument..
Unless you live in the middle of nowhere and listen to stations that are already weak signal, I highly doubt you'll notice any difference. If you do like to listen to stations that area already weak signals prior to tinting, then ok, an argument can be made here.
different type of signal.
Old Sep 24, 2008 | 09:54 AM
piccirm's Avatar
difference between ceramic vs non-ceramic is around $150. I could use that for the roof spoiler.
Thanks again for the useful info
