Side Marker Lights...
Old Oct 1, 2008 | 09:15 PM
c350driver's Avatar
C 350
Does anyone know how to take out the amber side marker lights?
Do you need to take of the bumber? I didn't have the heart to try a firm pull, but they seem pretty determined to stay in there!
Anyone?
Old Oct 1, 2008 | 09:26 PM
VaderSS's Avatar
'06 E55, W204 C350, '04 Carrera C4S, '02 ML55 (Wife's)
Welcome to the forum!
Please do a search.... clear corners, smoked corners, etc.....
Search is your friend.....
basically turn the wheel right if your doing the left marker.
remove the three push pins in the wheel liner.
move liner out of the way being carefull of the paint.
now you should be able to see the marker from behind.
remove bulb by turning 90 degrees
remove torx screw (i think its #20)
push down on the upper plastic clip to release the top
rotate out and up....
This is from memory
Old Oct 1, 2008 | 09:30 PM
got_thang?'s Avatar
2008 C350
Basically what he said but there isn't a torx 20 tool
Old Oct 1, 2008 | 09:33 PM
syrAMG's Avatar
W212 2011 E-350 4Matic
Anyone?
Hey welcome to MBWorld its pretty simple to remove
here's the link
clear side markers
its a bit of a trick to get them back in though trying to get the bottom hook in place.
Old Oct 1, 2008 | 09:35 PM
got_thang?'s Avatar
2008 C350
here's the link
clear side markers
I'm used to it
VaderSS's Avatar
It's a torx somthing? promise... I put it back when I swaped in the smoked corners.... I know it wasn't a regular screw.
Old Oct 1, 2008 | 09:36 PM
got_thang?'s Avatar
2008 C350
Must be with the later C300/350 then I never had to take any screws off
Old Oct 1, 2008 | 09:41 PM
VaderSS's Avatar
got_thang?....
Good point... I just picked mine up on sept 15.... you can see my temp Lic. plate in my sig.... in hawaii we have 30 days before getting a plate...
Old Oct 1, 2008 | 09:44 PM
got_thang?'s Avatar
2008 C350
got_thang?....
Yeah that's how I know you got a newer C class
Old Oct 1, 2008 | 10:25 PM
c350driver's Avatar
C 350
This is from memory
Thanks guys for the quick reaction!
And SyrAMG I followed your link and thats a great help! Ill try it out tomorrow!
Thanks for the help!
