no display on the audio system
The audio system appear to be functioned correect without any visual display in the dash console.
I try to turn on and off the engine, switch on / off the audio bottom still no visual display
Have I done something wrong or is this a fault with the audio system ?
The display in the cluster still works, BUT not the screen display behind the flip door above the air-con.
I try press the arrow bottom on the steering wheel; which doesn't since to help
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
not a common problem, Will be an easy/quick FIX i reckon. Other display menu working? like Navi , DVD , telephone, System? or the COMAND screen is altogether Blank for everything?
Not surprisingly, I had something similar happen at around 2,500 miles. My MM screen just stopped raising itself when I turned the car or audio system on. The screen stayed shut for 4 days while I waited for yet another warranty repair appointment to fix it. The audio system worked, I just didn't have a screen I could see. Nothing, including pressing the open/close button on the screen unit worked to get it to open.
The day before the car was to go back to the dealer, I got in, started it and the screen opened like it was supposed to. It's been fine since. I'm puzzled why there isn't some switch or setting to just make the screen stay in the "up" position all of the time instead of closing when you turn the car off.
mercedes benz 2008 c 300 sport sedan
i had the same thing happen to me befor i crashed mine. I turned on the car and the screen in the dash didnt come on. i turned the car on and then off and then on again and still nothing. when i hit the power buton and turned it of then on again it worked.
E500(Sold), SL500(Sold), C350(Sold), ML350, SL65
Also check the fuses box under the hood there are two fuses that the system run off of..fuses 11(71/2amp) and 26(20amp).
BAD quality .....
Quick update after visit the workshop last week. The work shop have to order a new display unit for my car.
They said they did everything they could still can't bring the display back.
Well ...... i am a bit disappoint with the quality of the car now with such a brand new car and things start to falling apart.
Non of my friends Japanese car have those little problems and they are way cheaper then Benz.
Its probably you manually switched the COMAND off before stoping the engine. or you switched it on and off while the car engine was not running. This makes it go in manual mode and then unless and unti you run the car open the screen and then shutdown the car it will not go into auto mode.
This is not a major problem you encountered. You will get a new unit and soon you do not have to worry about anything.
Its just a matter of luck. I never had any problems with my car but then again my brother two months old 2008 BMW has been to garage 5 times already for different problems.
Thanks for the encouragement, the dealer have to wait for one week for the unit to be arrived. Then again, who knows what else could be damaged during the replacement; if you know what i mean.
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
It's a car not a perfect being for goodness sakes! things will go wrong sometimes, it just happened to you, relax and enjoy the car.
Just spoke with service manager.
They been troubleshooting this issue ALL day still have no clue after replace the new unit.
I will post the root cause once i get back my car.
BAD thing happen
Suppose to be a good day, the dealer fixed the display unit.
BUT there are deep cut marks on the leather seat when pick up the the car, I was so ****
Other than the leather been cutted, looks like the side panel next to the glove box also been open and not put back properly; base on the YOUTUBE video where you don't need to open the side platic panel to take out the display unit
After all these, i guess you better take photo of ur car before take it to the dealer for service.
Now I have to wait till the coming Monday to speak with service manager, i bet they will deny everything.
