Reprogramming Express Driver side window
Old Oct 26, 2008 | 10:04 PM
idragen's Avatar
MB C300 Sport Palladium Silver/Black
Hi guys - I tried to do a search for this as my driver side express auto up seems to have deactivated by itself but didn't find much info. Does anyone have some quick instructions on how to re-program it? Much appreciated. Thanks!
Old Oct 26, 2008 | 10:07 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I believe it may be more of a hardware(bad switch) than software problem
Old Oct 26, 2008 | 10:11 PM
idragen's Avatar
Thanks for the response. When I did a search some one had the same problem and others mentioned that they can re-program it. Not really sure but I have tried to hold the switch up for about a minute to see if that worked but didn't...
Old Oct 26, 2008 | 11:58 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Reprogram
Do it again. Run it all the way down and hold the switch for 15 seconds and then run it all the way closed and hold it again for 15 seconds.
Do all four windows.
This is the same way the sunroof is reprogrammed.
Old Nov 1, 2008 | 02:23 PM
idragen's Avatar
thanks I just tried this but didn't work. I'll try it again but seems like it will be another trip to the dealer unless someone else has any other suggestions.
Old Nov 1, 2008 | 02:31 PM
Diesel Benz's Avatar
Does the one-touch feature not work either way? Do you feel the different pressure point at the button for the one-touch case?
Old Nov 1, 2008 | 02:40 PM
idragen's Avatar
it works going down, and it also works for up and down on all the other windows . I don't know if the pressure point feels different though
Old Nov 2, 2008 | 04:26 PM
m1rked's Avatar
2009 C350 Sport
The same exact thing happened to my car, down would work, but up didn't. I just took it to the dealers and they finished the same day. Good Luck!
Old Nov 3, 2008 | 01:56 AM
But you don't know how it was fixed or you don't want to share the info? Was it a broken switch that was replaced or still an issue with window motors normalisation.
