Originally Posted by white46
(Post 3916115)
I am not sure what eu-40 is but, you can just purchase this which is pre-maid with RCA output. Just easier solution. :)
http://cgi.ebay.com/Radioa-Extension...item3a53d33a84 thx for the link.....can't wait to install the camera asap....btw for u guys (near socal area) if u want to order the backup camera, u can order thru this place http://www.sonicelectronix.com from my understanding....u can go there and p/u your order and they have great service....(45mins away from LA) |
Originally Posted by f8al
(Post 3921094)
You guys are making this look too easy, I gave in and started ordering my parts today....
There's a step about splicing a wire to the reverse lights to give the camera power, that I'm a little weary about. There isn't much detail for what seems to be the most crucial part. I'm thinking it will make more sense when I'm actually doing the install.
f8al, that step isn't as difficult as it seems. The easiest way that I've found is to strip back some of the insulation on the wire that you're splicing so as to have the copper exposed, but not broken. Wrap the bare wire that you're splicing onto this exposed piece of copper and tape the whole thing up. I've done this numerous time when splicing to factory wires.
Thanks! I was picturing some wire nut splice configuration, but your suggestion makes a lot more sense.
Just go to Radio Shack and pick up a pack of these.
http://www.radioshack.com/product/in...ductId=2104093 |
2 Attachment(s)
just finish install the backup camera last week....all the instruction are
helpful...but i need to comment some more info because i have some area which i have trouble......Spec for my c63: APP (Canadian Version P30 w/lsd) Premium Package, Carbon Trim, Sat. radio, Keyless Go 1. My kenwood backup camera require Accessories wire (red) to hook up, and i spliced to a wire going to cig ligther fuse (Pink wire) (pics will provide later) 2. for the steering wheel control to activate the backup camera funtion for my Command system, it didn't work for me, therefore i access the engineering manual by pressing 1 , # and hang up key...then i goto menu 7.7.17 to turn the backup camera funtion on. But i don't know why there is 3 option to choose, so i try each one...none of them work,everytime when i put in reverse ,also even if i turn off the car and turn on right away, it still doesn't work. At last, I have figure it out! To Turn on the backup camera function for the my kenwood camera, first go engineering menu 7.7.17 , then choose SRVC, next turn off the car, not sure if require to lock the door or not...but i locked the door....leave the car for 5 mins....then start the car, put in "R", the backup camera screen will be turn on. |
1 Attachment(s)
sorry, have to borrow the pics from the previous post!
I have spliced my acc wire from to this wire! Note: spliced to red circle area! |
Originally Posted by dacatz
(Post 3987967)
not constant 12v....that is ignition on and u will get 12v in that wire...
It might just be stupid me but let me get this strait. We need a FRAKA to RCA because FRAKA is need to connect to the back of COMMAND, and RCA is to the back up cam?
Also for the FRAKA to RCA adaptor should the RCA be male or female? |
Originally Posted by rst63
(Post 4091054)
Yes! Also for the FRAKA to RCA adaptor should the RCA be male or female? |
Thanks alot! Also i noticed that for the camera, there is 3 connection or wires that should be connect. Ground, Power, and Reverse light. I understand where the ground should be connected but where do i connect the power and reverse? should both be connected to the reverse tail light?
(Post 4091972)
Some people run the ACC wire all the way to the front to the cigarette lighter, but I preferred to keep it clean, so i kept it back there. I forgot which one I put it to, but I'll let u know later when I re adjust my camera either today or tomorrow. The reverse should be connected to the reverse lamp. |
This is a little off topic from the OP, but i noticed that there is a Blue port for AUX audio. is that what is used if someone wanted to install a system with bass? or is that for ipod integration?
thanks. |
This fakra adapter.. can it be found at Radio shack? or... I just got my camera yesterday:) and want to do this tomorrow, not wait for an ebay cable!!
The radio shacks around me do not sell FAKRA adapter. I just bought mine from mid city engineering.
Boo.. maybe i'll get lucky at a bigger electronics store...
waiiiiiiiit.... I just bout the CMOS-200 will this one work??? i see the guys using CCD-2000... .. does it matter?
Originally Posted by blue00r6
(Post 4134970)
It doesn't matter. I tested both teh CMOS-200 and CCD-2000. Dont' ask why I bought two. lol :p |
what is the difference between the two?
Originally Posted by na011
(Post 3137117)
You need to use MS Internet Explorer Browser. When I use Google Chrome or Mozilla Firefox browser I also have the "red x".
Originally Posted by joshg1001
(Post 4135471)
Originally Posted by I am Jeff
(Post 4137451)
On paper, slightly better resolution and better viewing angle. But on the screen, basically same thing.
how are you all snaking the rca cable from rear to front? is taking the interior trim/carpeting apart required?
