Another broken foglight!
Old Jan 7, 2009 | 11:32 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
Originally Posted by Ron Jr
www.lamin-x.com
Lamin-x film is thick and should prevent breakage. I use the yellow on mine.
Has anyone tried their product for the whole front? I'm interested but I'm not sure if it's that invisible
Old Feb 12, 2009 | 09:36 PM
Bokx_350's Avatar
C350
Originally Posted by white46
fix the broken fog-light yourself, parts cost around $100, bolts are little awkard but it's doable. not too hard.
put clear 3m film on it (which I did) or buy plastic fog cover from ebay.
The dealer quoted me $177 + tax just for the fog light, no labor. Anyway to get it cheaper?
Old Feb 12, 2009 | 09:59 PM
spoolIT85's Avatar
C300 sport 4matic
I got the full front fog/head lamp from lamin-x and works great... not so paranoid about get rock/salt/snow hitting the glass enclosure for the fogs. since the headlamps are plastic, it might be a bit overkill-
With labor and tax you should be around $300... I should know cause I paid for installation since it was too cold in Chicago to replace it myself.
Old Feb 12, 2009 | 11:28 PM
Bokx_350's Avatar
C350
I guess my question is is $177 the real price? I thought it was around $100. (not that it makes that much difference anyways).
Old Feb 12, 2009 | 11:56 PM
Bokx_350's Avatar
C350
Anyone has laminX on their headlights? Should I get these as well?
Old Feb 13, 2009 | 12:52 AM
kaku's Avatar
2009 C300S 6mt
Is the film quite noticeable? That is, about how far from the vehicle would you need to be for it to be invisible?
If you have, pictures would really be nice=)
Old Feb 13, 2009 | 08:48 AM
  #32
whiteongrey's Avatar
'20 Targa 4 DD, ' 18 Volvo S60 T6
Originally Posted by Spec_Davis
Lamin X
2nd that - first and only thing I had done to the car immediately after delivery. had them put on the thicker one for light protection and no problems. Not noticeable from even a couple ft.
Old Feb 13, 2009 | 08:59 AM
  #33
spoolIT85's Avatar
C300 sport 4matic
i purchased the headlights as well, but if you ask me, i think its a little over kill since its already made out of high strength plastic - just save the money...
pictures wont really help since i just bought the transparent film
there are two types of film you can get, one thicker than the other... fwiw, i bought the thinner one (easier to install) and you can tell a noticeable difference if you tap the glass, before and after install
Old Feb 13, 2009 | 11:37 AM
  #34
jstaneff's Avatar
C-300, XC70, Wrangler
Plastic headlamps will get pitted over time, reducing the quality of light that is thrown out front. Using a head-light cover/bra/laminix product will preserve the plastic, and you can easily swap out the cover.
Old Feb 13, 2009 | 12:52 PM
  #35
spoolIT85's Avatar
C300 sport 4matic
pitted enough to reduce quality of light?
Old Feb 13, 2009 | 06:20 PM
  #36
jstaneff's Avatar
You obviously don't keep your cars very long. On the car I'm thinking of, the plastic/lexan headlamp covers were about 9 years old. I replaced the bulbs, but the light quality was still bad. Close inspection showed the plastic covers to be badly pitted.
Why? Well, we don't salt our roads, we sand them. All that sand gets sprayed up onto our cars. The W204 is my second car with the clear bra, and all my previous cars had dulled headlights and pitted hoods before I traded them.
And, I keep my cars for anywhere from 9 to 17 years, so yeah, pitting happens!
Old Feb 14, 2009 | 12:52 AM
  #37
Savage c-300's Avatar
C300 Sport, MM, P1
Lamin X
I agree. I put LaminX on my fogs light and have not had a broken light EVER. That stuff is cheap and it works!
Old Feb 15, 2009 | 10:38 AM
  #38
dansonchan's Avatar
2009 C300 Sport 4MATIC™ Sedan
idk how to install laminx by self...?!??!
any one can teach me?
i did order fog light n front light...but the size doesnt fittttt???
Old Feb 15, 2009 | 04:29 PM
  #39
spoolIT85's Avatar
C300 sport 4matic
just make sure you heat it up with a blow dryer... the warmer it gets, the easier it will be to apply the material. a heat gun will generate too much heat and would not be ideal...
if all else fails, call their customer service. they're pretty helpful.
Old Feb 15, 2009 | 11:38 PM
  #40
If one does a lot of 50mph+ driving the road grit will damage the plastic lens over a few years - like a weak sand blaster. If in a snow region the rocks will trash them in no time.
I hardly drive on the freeway and when I do it's in the summer only (I'm leisure driver) so never did the head lights.
Old Mar 2, 2009 | 12:47 AM
  #41
ongster1's Avatar
2008 C300-Sport/Palladium Silver/PII/Panaroma
Well, it finally happened to me. Broken foglight! Rock went through the driver side foglight. Local MB dealer in Seattle quoted $150 + tax for the replacement part. Has anyone ordered the replacement foglights from this ebay seller?
http://cgi.ebay.com/ebaymotors/07-08...Q5fAccessories
Pretty decent price at only $80 for a pair. They say the foglights are made by HELLA. Just curious of the quality and fitment. Thanks!
Old Mar 2, 2009 | 01:54 AM
  #42
JimPap's Avatar
2008 C300 Sport, RWD, US
ongster1,
I think those are the actual lights where many on this thread are talking about the housing lens.
Guess you need to be sure what's broken on yours.
Old Mar 2, 2009 | 11:23 AM
  #43
Bokx_350's Avatar
C350
Good question. I also saw this ebay package and decided to stay away bacuase they seem generic. However, if someone who has seen the OEM light can compare it to the one on ebay and confirm that they are the same it would be worth it.
Edit:
"This auction includes everything needed to install and requires no other parts or extensive modification" No extensive modification? who defines what extensive is? I'm out
Old Mar 2, 2009 | 10:52 PM
  #44
ongster1's Avatar
Edit:
Yeah, I saw that disclaimer too, but I'm thinking that might be just a generic one they use for all their other foglights. That's why I was hoping someone here would have some personal experience with that set.
Anyone?
Old Mar 2, 2009 | 11:06 PM
  #45
cdye12's Avatar
09 C350
Edit:
Dunno, but when I cracked one of mine, it was the light AND the housing, around 300 bones after labor if I recall correctly.
Old Mar 3, 2009 | 07:51 PM
  #46
ShoremNJ's Avatar
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
I put film on mine and still cracked one! the lenses should be made of Lexan not glass.
Old Apr 2, 2009 | 05:15 AM
  #47
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
The yellow lamin-x film looks really good..I have a quick question, does the film alter the fog light color or increase/decrease lumens in any shape form??
Did you guys replace stock fog light bulb w/ something different after apply the lamin-x film?
Old Jun 16, 2009 | 10:58 AM
  #48
krh's Avatar
krh
'08 C350
I looked at the Lamin X website, and it gives different mil thicknesses you can buy. I would like to go as thin as possible, but don't want to waste my time putting something on that won't protect the lense... What thinkness would be recommended? Any different for the headlights?
Old Jul 6, 2009 | 07:41 PM
  #49
MB_AMG's Avatar
Audi S4, Mercedes Benz C350 4Matic
i bought it from dealer.
No white46, you bought it from me!
Old Jul 6, 2009 | 11:23 PM
  #50
aowhaus's Avatar
2008 C300 Sport 4matic
I got the headlight & foglight kit from Lamin-X and I am very happy with it.
Heating the film with a hair dryer doesn't work that well as the material is thin and cools down fairly quickly. I just keep the headlights on and the heat from the lights is enough to keep the film soft and pliable.
Be sure to keep the surface wet and apply the film slowly so that you could press the air bubbles as you go along (it's easier to do it at this point rather than later). The instructions says not to put too much water on the lens, which I took very literally which made squeeging out the air bubbles very difficult.
The film will look like crap when you first install it, but the haze and bubbles will disappear over time as the moisture and adhesive will disappate through the film. Parking your car in sunlight will speed up this process.
I went with a very light tint for the headlights which made it look like the C63 headlights. I went with yellow for the fogs, but I'm sure about the look of them. I will replace it with clear soon -- I already have rallye yellow bulbs for the fogs for poor weather conditions.
