Headlight fuse
Old Dec 20, 2008 | 04:23 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Headlight fuse
OK I looked at the fuse allocation chart that was with my car (hidden in the trunk). None are shown for the headlights. My passanger side one went out so I replaced the bulb with a new one, still out thi is strange so I switch the bulb with the drivers side that does work still no good. It must be a fuse but the chart does not help. Any idea what number the fuse for the passanger side headlamp is? BTW high beam works fine.
Old Dec 20, 2008 | 05:52 PM
e1000's Avatar
a quarter mile at a time
There are no fuses for any of the exterior bulbs. They are all computer controlled. Are you getting a bulb out error?
Old Dec 20, 2008 | 05:54 PM
Ron Jr's Avatar
Yes I am.
Old Dec 19, 2013 | 02:24 AM
saturnlod's Avatar
2008 c350
I am having the same problem what do I do
Old Dec 19, 2013 | 09:26 AM
tonyteetime's Avatar
2013 C300 sport 4matic
https://mbworld.org/forums/c-class-w...bulb-good.html
check this thread.
Old Jan 19, 2022 | 07:12 AM
Mercedes man56's Avatar
2008 Mercedes-Benz E350
Right side low beam out solution
Right side low beam
Old Jan 24, 2022 | 08:40 PM
Steve706's Avatar
I'm a mechanic work on all
03 c class
Alot of newer cars set a code when bulb blows. I am actually working on one and was looking for fuse box diagram and maybe a reason why lt headlamp wouldn't work with new bulb and couldn't find answer. This car c class im on had a headlamp code and battery was actually dead with my junp box on it and all I did was unhook jump box and then hook it back up and walla it works. So either clear code or disconnect battery to clear code so computer will send signal.
Old Aug 17, 2022 | 09:39 PM
Blurrat120MPH's Avatar
2012 c300
You mentioned there was no retainer clip in the headlight for the bulb... Doesnt that have to be there in order to secure a ground connection? They do in my headlamps. Just a thought. Not sure if anybody else mentioned it as I did not read the entire thread just thought I would throw that out there. Good luck
