Weird noise at idle!
2008 C300
I am getting a very weird "ei ei ei ei ei ei" noise that never goes away from the engine at idle to about 2000rpm. At higher rpm the "ei" noise repeat faster than at idle. it sounde like a 10yr old car. sounds like somthing with the belt?
If it only occurs when the AC compressor is running, does it sound more like a pressure leak or a belt squeak? Since NewtonLaw's squeak never goes away, it may be the AC compressor clutch(if these are the same sounds)
I also noticed an old document about noise from the compressor area, but I would assume this concerning older W204 cars.
