Transmission Fluid
I have the 5 speed auto box & there is a drain plug in the pan & the pan is easily removed by a few bolts . Make sure you put exactly the same amount of hydraulic oil in that came out. I do not have a dip stick in mine so you may have to inspect the dealers, measure up carefully & make one yourself.
