Old Jun 10, 2015, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Question on resetting the ECU
Old Feb 11, 2009 | 11:47 PM
hadjionm's Avatar
w204 c220 cdi auto
Hi All,
I found these instructions elsewhere on this :
"Steps to Reset the TCU.
Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset."
My question is, in (1.) what is meant by the "on" position. Is it the first click stop after turning your key to the right, or the second click stop?
Old Feb 12, 2009 | 01:01 AM
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
i think it is the second position right before engine crank. this is the same spot as when you enter dyno mode...
Old Feb 12, 2009 | 05:09 AM
Petje's Avatar
W205 C400
It's the first position (click)
And it will reset your transmission, not your ECU (like the Title of the topic says)
Old Feb 12, 2009 | 09:41 AM
TB5...'s Avatar
2009 C300 4Matic
what a coincidence...
Old Feb 12, 2009 | 10:13 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I was going to search for TCU reset this weekend. Thanks.
Old Feb 12, 2009 | 10:37 AM
TB5...'s Avatar
2009 C300 4Matic
is there a way that i know i did it right?
a beep? a msg i should be lookin out for?
Old Feb 12, 2009 | 04:32 PM
hadjionm's Avatar
w204 c220 cdi auto
Thanks Petje.
Do you know whether there is a way to tell if it has taken effect?
Regards Matthew
Old Feb 12, 2009 | 04:40 PM
TB5...'s Avatar
2009 C300 4Matic
echo...
Old Feb 12, 2009 | 09:42 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
No way to know if it works. I tried it before and nothing changed. Let me know if you guys experience anything.
Old Feb 13, 2009 | 02:25 AM
erikguti's Avatar
W204
does it work on european models????? i have a 09 c230
Old Feb 13, 2009 | 02:42 AM
Petje's Avatar
W205 C400
Have tried it, no beep confirmation that its done...
No big noticable difference...
Old Feb 14, 2009 | 07:00 PM
F1Bobby's Avatar
From: People's Republic of California (Southern Region)
C55 AMG, CLK550
Just did it. Seems to have helped.
Old Feb 14, 2009 | 07:33 PM
BerBer63's Avatar
2009 C63
"On" Positions is just before engine start up, so 2 clicks to the right after the key is inserted.
It's more of a throttle reset, but it's noticeable if you run your car hard after it's been done, so warm the engine up first then do the reset.
Old Feb 15, 2009 | 08:49 PM
hadjionm's Avatar
w204 c220 cdi auto
Hi Guys,
In summary:
*it seems we are unsure which click stop it is, one or two
*it seems that those who have tried it don't feel much difference, if any
*it seems that there is no way of knowing whether it has taken effect, or whether it has been done correctly.
Sounds more like faith than science!
Does anyone know where these instructions for resetting the TCU came from?
How do you reset the ECU?
Regards Matthew
