"Unreadable Files" on memory card???
Old Mar 20, 2009 | 02:59 PM
NJBNZ's Avatar
'09 C300 4Matic Sport
Slid the PCMCIA card and SDHC card into the dash and it says unreadable files on memory card on the display. What does that mean? What format do the songs have to be in? MP3 right? COuld it be because I have them broken up into separate folders?
Old Mar 20, 2009 | 05:55 PM
NJBNZ's Avatar
So I just downloaded a converter and converted the ITunes files to MP3...still didn't work...any ideas?
Old Mar 20, 2009 | 06:27 PM
Xaniar's Avatar
E200C-Fully loaded, Obsidian Black, ILS, Panoramic roof and some other bits and pieces.
The only format you can use is mp3, it doesn’t matter how many folders you have it should be able to show all the folders and read the mp3 files. If not then check the SD on your computer and make sure the card is functioning if it does then just format the SD card and then put the files back on it.
Old Mar 20, 2009 | 07:11 PM
BerBer63's Avatar
2009 C63
Your PCMIA probably doesn't accept SDHC over 2gigs probably or was it 4...
Old Mar 20, 2009 | 11:16 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
2 is the limit for non SDHC, that would be my guees. Try a smaller card, 1 gig cards can be had for a couple of dollars.
Old Mar 21, 2009 | 12:26 AM
aprince2die4's Avatar
08-C350 black/black
i've got the sandisk ultra II sdhc 4gb card and it works...
Old Mar 21, 2009 | 03:00 AM
Diesel Benz's Avatar
But your "PCMCIA" is SD HC capable, the comment was about adapters that do not support SD HC.
Old Mar 21, 2009 | 10:28 AM
Ron Jr's Avatar
Also does command need to read files saved in FAT32 or NTFS? I know NTFS works because thats what I use but
Im also only use 2 gig cards.
Old Mar 21, 2009 | 04:05 PM
NJBNZ's Avatar
Okay are you guys ready for the detailed and technical solution I found for the problem?
So after I converted all the songs and re-saved them onto the card that didn't work. So after hours of searching online for a solution i went outside and tried it again...no luck. So I took out the card and blew into the end of the PCMCIA card that connects to the dash...and VOILA! It worked hahaha
Old Mar 21, 2009 | 04:07 PM
maverickvii's Avatar
2008 C300 Sport 6M
NES style fix, I like
Old Mar 21, 2009 | 05:22 PM
Xaniar's Avatar
I guess a good old blow beats all the new tech hanky panky.
Old Mar 21, 2009 | 06:16 PM
NJBNZ's Avatar
hahaha that's exactly what i thought of when it worked
Old Mar 27, 2009 | 11:15 AM
doms1214's Avatar
C300 Sport
Do you happen to know if an ipod is supposed to intergrate directly with the system. Meaning you could control the ipod through the multi media system and change songs, etc? Or can you upload from the ipod to the cars hard drive??
Old Mar 27, 2009 | 11:44 AM
Ron Jr's Avatar
It is at best a mediocre interface for the I-pod. It is not controlled thru the command interface but thru the dash display. Most likely so one solution would work with all OEM stereos. I have it but don't use it the indash reader in the MM system is better. I have not really used the HD yet.
