C320 Location of Speed Sensor Pickup?
I'm inquiring as to the location of the ABS Speed Sensor Pickup in the C320. Is it located within the ring of the wheel seal? Where exactly is the speed sensor getting its signal from?
Thanks much
http://www.detali.ru/cat/oem_mb2.asp...SGR=663&SGN=26
You should be able to find it if you follow the wire.
What are you up to by the way?
