TPMS help
Old Apr 24, 2009 | 10:56 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
TPMS help
i just replaced one of my tires because i had a flat two days ago now i need to know is there any way to reset the TPMS so the car can recognize it?
Old Apr 24, 2009 | 11:03 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Just do a reset using the dash menu.
Old Apr 24, 2009 | 11:04 PM
Spec_Davis's Avatar
more details plz...
Old Apr 24, 2009 | 11:08 PM
ptronus31's Avatar
2008 C300
Check your pressures when the tires are cold then go to the settings menu on the speedo screen, go to the tire pressure menu and tell it to use the current pressures as the set point. The wording is different but that should get you close.
Old Apr 24, 2009 | 11:13 PM
Spec_Davis's Avatar
okay thanks i will try that out.
