Moisture in fog lamps????
Old 05-10-2009, 04:26 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
I've been getting moisture bubbles on the lens of my fog lamps for quite some time.
Last Thursday, I think I got them underwater (flash floods) and I saw that they were holding water. Well I was able to get a shop towel into them to soak up the water and clear the lens.
I noticed tonight when I got home, I've got those moisture bubbles on the lens again.
Seems that the housings are not moisture tight. Would this be covered by warranty?
I also burned out the low beam headlight. Is that covered by warranty?
Old 05-10-2009, 08:59 AM
spoolIT85's Avatar
C300 sport 4matic
Since the cause is due to flooding, I doubt you will get it warrantied.
Wear and tear parts such as headlight bulbs aren't covered by warranty either.
Old 05-10-2009, 04:49 PM
JimPap's Avatar
spoo
Since they were getting the moisture before the flooding, would that not indicate that they were not sealed to start with? Or is this common?
Quick Reply: Moisture in fog lamps????
