Retrofitting COMAND (MM) writeup.
Rating: Thread Rating: 3 votes, 5.00 average.
Old 10-08-2013, 04:56 AM
  #226
vic viper's Avatar
S213
My guess is that your HU is setup for Audio System wich communicates through the MOST bus, enter engineering mode to see if you can find any settings regarding this.
Old 10-08-2013, 03:31 PM
  #227
hliu6's Avatar
Mercedes Benz C300
thx for the tips, vic..
I will try it later and let you know.
thx
Old 10-08-2013, 04:25 PM
  #228
hliu6's Avatar
Mercedes Benz C300
hi vic, I tried some options on the engineering mode.but does not work.
Old 09-10-2014, 04:52 AM
  #229
voorat's Avatar
2008 c63
Sorry I need to ask seeing that it seems you have a lot of experience in this...My 2008 C63 radio and command centre has no power to them...I checked the fuses 11 and 26 and also the fuses on the back of them but all are fine....any idee what the cause might be?
Old 09-10-2014, 08:28 AM
  #230
hliu6's Avatar
Mercedes Benz C300
if u upgrade from audio 20, you should order a new cable. The black cable has to be changed, it looks the same, but cannot power the HU.
Old 09-10-2014, 08:59 AM
  #231
voorat's Avatar
2008 c63
Thanks for the reply but my car came standard with the command centre...it was working got to the car 1 day and it all was dead...no power...
Old 04-17-2018, 06:45 PM
  #232
masekoad's Avatar
mercedes w204 c200 2009
Retrofitting the w204 harness
Thank you for the detailed write up. I appreciate all your efforts. I have done everything except removing the IC to attach the fan. Could you please reload the photos. My ride is RHD. Thank you.
Old 01-08-2020, 05:10 PM
  #233
Toffe93's Avatar
W204 320cdi, W124 300DT, W203 220cdi
Vic Viper, Can you put PM or something have a few questions about this Retrofit
Old 04-06-2021, 11:07 AM
  #234
dsenela's Avatar
2008 C300 4MATIC SPORT
Deleted
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Retrofitting COMAND (MM) writeup.
