How to remove glove box
Old Jun 19, 2009 | 02:01 PM
tw1nny03's Avatar
2008 C300
Does anyone have instuctions with pics on how to remove the glove box?
Thanks.
Old Jun 20, 2009 | 12:39 AM
got_thang?'s Avatar
2008 C350
What are you trying to do?. I might post a guide later on
Old Jun 20, 2009 | 04:03 AM
vic viper's Avatar
S213
Its pretty easy, remove the plastic cover under the glovebox, three torx screws, remove the connector for the light and fold away a plastic latch in the middle as you pull it out.
Then remove the dash side panel to reveal another screw, Inside the box you must remove the aux connector, there is a small plastic washer covering the connector, pry this out and pull out the connector throgh the side cover opening,
then there is three or four (cant remember) screws inside the glovbox, in the upper part and in the leftmost part, one of them can be a bit tricky to see and remove.
Once this is done pull the box against you if your sitting in the seat, diconnect connectors to 12V socket and box illumination and the glovebox is out.
Old Jun 20, 2009 | 08:19 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
vic your wagon is super sexy!...any tint planned?
wish they had wagons here...350 i assume right?
Old Jun 20, 2009 | 08:41 AM
vic viper's Avatar
S213
Thanks , yes a tint is planned, going for a light tint all the way around.
I wish it was a 350, but my car with an engine like that would cost as much as a C63 for you maybe even more ..
Its a Blue Efficiency 180 Kompressor, around 160PS with great gas mileage.
Old Jun 20, 2009 | 10:48 AM
got_thang?'s Avatar
2008 C350
Yeah like vic said it's very easy
Old Jun 20, 2009 | 10:34 PM
356SC's Avatar
ML350 W164
Hope this helps, it is on a RHD model.
This is the plastic cover after removal. There are 3 screws. Note also the catch mentioned by Vic.
The location of the rest of the screws for the box.
Old Jun 22, 2009 | 10:38 AM
tw1nny03's Avatar
2008 C300
Im trying to remove the glove box to install the upgraded ipod cable.
Old Jun 22, 2009 | 11:17 AM
tw1nny03's Avatar
2008 C300
Does anyone know how to take off this piece? Looks like I wouldnt have to take the glove box out to replace the ipod interface cable.
If I took out this trim piece, I would have access to the ipod cable connector.
Old Jun 22, 2009 | 12:59 PM
qwqwerertyty's Avatar
2009 C350
1. just start from pulling out the bottom and you should be able to make a gap quite easily.
2.then try to stretch open the gap by gradually running up along the edge near you.
3. when you reach the tip, carefully pull the panel towards the door. the side near you is held together by 3 clips and they're pretty tight. the other edge of the panel is held with a hinge sorta thing that comes off at an angle, if you know wt i mean...
and so as i've tried to say in the other post in the other thread.. that's the only panel you need to remove to access the ipod cable..
i know im a bad explainer. but i'm happy to answer questions =]
Old Jun 22, 2009 | 04:21 PM
tw1nny03's Avatar
2008 C300
Do you have any pics?
Old Jun 22, 2009 | 10:24 PM
356SC's Avatar
ML350 W164
tw1nny03, pictures of the side panels (RHD). Just notice the position of the clips.
Old Jun 23, 2009 | 01:35 PM
tw1nny03's Avatar
2008 C300
Thank you so much 356SC!!
Greatly appreciated bro!
Old Jul 22, 2012 | 06:38 PM
rwilson610's Avatar
2011 C300 Sport
Hey fellas I dont have a manual for the W204 2011 C300. Where is the cabin filter located?
Old Jul 22, 2012 | 07:41 PM
Domm's Avatar
'08 Mercedes C300
https://mbworld.org/forums/c-class-w...in-filter.html
I'm not sure if it's the same as the facelift. Should be similar
Old Jul 22, 2012 | 07:57 PM
steven1888's Avatar
2008 c350 sport
kinda similar topic... i took the side panel off and drag in the aux. the thing it when i use it .. there is only sound coming out on the passenger side ? why is that?
Old Jul 23, 2012 | 04:58 PM
kHuNkHuNa's Avatar
White 2009 C300 Sport
try a new aux cable, or a different device, first
Old Aug 27, 2014 | 10:08 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
Hate to resurrect an old thread, but I'm trying to pull the glovebox to connect a DVR to the 12v lead on the glovebox lighter plug.
It's a 2010 GLK 4Matic with Premium 1 and Multimedia.
The bottom panel removed with the 3 Torx screws and the side panel wasn't too hard to pry off. The glovebox had only 1 screw on the top edge and none along the side panel near the cluster. The jack is an iPhone jack.
I can't find the rest of the screws (after careful examination with a flashlight) and I can't figure out how to loosen the iPhone jack - if I need to. The screw on the sidepanel edge was there and I removed it but taking it out and the one screw on the top edge still leaves me with a very secure glovebox. There was a little grey adjuster (for air to the glovebox?) I easily popped out. No screw under there. There is another small black square with a slot that seems secure too. I can't find another screw anywhere.
Anyone have some ideas? I'm stuck. Thanks for the intervention!
Old Aug 28, 2014 | 08:55 AM
codeblue5007's Avatar
2008 Mercedes Benz C300 4matic Sport
If the glovebox feels solidly connected you have probably missed a couple of screws. Look carefully at the picture in this thread with the orange tabs showing the location of the screws. As for the AUX jack, I remember pushing in and rotating the outer ring (in the glovebox) just a little, until the "teeth" of the ring lined up with the gaps between the teeth connected to the jack itself. The outer ring will then be freed into the glovebox and you can pull the jack through the hole. Basically, the "teeth" connected to the jack in a circle contract to fit in the hole and then expand once the jack is in the hole. The ring secures the expanded teeth of the jack. I don't know what this ring lock is called, but I hope this gives you an idea of how it works. It's very delicate. Don't force anything. Hope this helps.
Old Jun 16, 2016 | 02:04 AM
nnkfws333's Avatar
C300
bumping an old thread but does anyone know how to swap locks between two glove boxes on the C300?
