Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Install Door Speakers
Step by step instructions for do-it-yourself repairs
front door h/k speaker retrofit (how to)
#126
2008 Mercedes Benz C300 4matic Sport
Rookie, I found the pins could not be reused. I pulled them out, rotated them and they wouldn't even go back in. And I had a helluva time getting the panels off because the vlips wouldn't come out easily. Someone rose commented that the pins weren't even necessary, since the panels reinstalled securely with all the damaged clips replaced.
The infinity tweeter will not fit in the plastic ring that held the original tweeter. The solution is to dremmel off the three plastic prongs that hold the ring, jam the new tweeter in the foam behind the sail and snap the sail in place.
As I mentioned I'm not entirely happy with the infinity tweeters, especially with fm rock music. Could be the lousy source or the orientation of the tweeters, or the fact that they are not fixed in place. Going to try Alpine tweeters, which by the way will fit into the original tweeter holder ring.
It's an interesting project and you'll find solutions as you go on. The rear,speakers are much easier than the fronts because there are no locking pins and window surround to take off. I used kappas in the back too and they fit just barely without touching the window.
#127
Thanks sincity and codeblue5007, my understanding here is that those are locking pins that are attached one each door and not reusable, therefore I should get a new one every time I open the door panel, correct?
Anyway, I found all these instructions from Akadan, Bill, VicViper and many other contributing MBworld, but I'm still not entirely sure how will I be replacing the tweeter since the housing size will not fit (Kappa Tweeters will be way bigger than the OEM, right?)
Still a bit nervous here since this is my very first speaker retrofit job. I took out a stereo from VW MK5 previously to attach an aux cable, but never did anything to the wiring of a car.
This job will requires me to:
- Open up 4 door panels.
- Use a tremel to sand all the previous fittings.
- Drill the holes using a 1/8" drill bit or smaller.
- resolder all the wiring.
Is there anything else that I should be aware of before tackling this retrofit, especially on how to do the wiring specifically?
#128
I understand your weariness. I didn't bother to replace that "square" clip. You will need to dremmel out the three plastic "rivets" to remove the factory tweeter and very easy to do. Just follow the guides and you'll be fine. I know Akadan used the stripe wires as +, but I found the electrical diagram from one of the pages that show the solid wire as "+". Most of my time was spent on finding an alternative place to mount the crossover for the fronts and ended up using the little cubby hole that ICON used.
#131
Mercedes e class, bmw 330i, Audi A6
Hey i want to retrfotit the hk tweeters in my car (2014 e class facelift) but i have some questions.
1.Is it easy to retrofit them
2.Will there be a difference in sound quality
3.how is it done ?
3.how is it done ?
#133
I've been driving a humble Hyundai Elantra loaner and it's sound system sounds better than the non-HK MB's. In other words, the non-HK MB sound system is mediocre even with Infinity speakers and a powered sub.
#134
Hey i drive a 2014 e class facelift w212 with standard speakers. I want to upgrade to harman kardon speakers. I do not want the amp I just want to upgrade my door speakers and tweeters. Just wanted to know is it possible to just swap the speakers or not, secondly will it be difficult to install and will i be able to hear a noticeable diff.
#135
Focal 165AC
Do you guys know if Focal 165AC can be installed?
I check on crutchfield and it says i can for lower front door.
Just want to double check if any have done this.
Cheers
Cheers
