Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: Why is My Interior Rattling?
Guide to diagnose trouble and recommended solutions
rattle in center console
W204 C280
I think I found the cause of the rattle! I literally took everything in the center console out of the dashboard and by process of elimination, I was able to pinpoint the rattle coming from the COMMAND screen.
I then proceeded to yank out the COMMAND screen and low and behold, behind it, I found a cable that moves up against it's plastic housing. I played around with it, moved it around and true enough, it made the exact same sound that I hear!
Here's a shot of the cable that I'm talking about behind the COMMAND screen. I pulled it out of its housing but when reinstalled back in the the dash, the cable is supposed to be flush inside the housing.
![](http://www.pbase.com/thealbert/image/115022298.jpg)
I then proceeded to wrap the cable with felt tape (sorry I don't have a picture for this, was too excited to have discovered the source of the rattle) and put everything back together. I then took the car out for a spin and true enough, I couldn't hear the rattle anymore! I'm one very happy man again!
Just for kicks, here's a shot of everything in the center dash removed.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://www.pbase.com/thealbert/image/115022297.jpg)
W204 C280
![](http://www.pbase.com/thealbert/image/115023939.jpg)
Thanks again! Cheers!
C300, 330i, MDX
Ang galing mo pare ko...
W204 C280
Going back to my rattle/tricking sound where my instrument cluster is, I took out the IC trim and the ticking/rattle was still there. It mainly happens when going over rough roads or accelerating or decelerating hard. There are 4 torx (20) screws holding the IC in place. I took off the IC and noticed that if I were to twist it, it's exactly the same sound that I hear. I then noticed that if I were to only install the bottom two screws on the IC cluster, the rattle would go away! So i reinstalled the top two screws but did not tighten it all the way. Just enough to make sure the IC doesn't fall off. Drove around for an hour and so far no rattle/ticking sound anymore! I believe the rattle/ticking sound is coming from the IC itself where when I drove over rough roads, due to the 4 screws, the IC cluster will flex, even just 1mm and will cause the ticking/rattle. Now with just the bottom two screws tightly holding the IC, I believe the IC doesn't twist as much anymore and therefore doesn't cause the ticking/rattle! At least in theory, it does make sense! I'm quite relieved that I was able to solve this issue cause it was driving me nuts for ages. I hope it just doesn't come back tomorrow though!
#33
Thanks for the replies guys, I was getting worried that I was the only one with this problem since my dealer said I'm the only one complaining about it.
I have the same problem Egonvdv has and the dealer was able to spot it right away since it was obvious. They put in some tape on the inside, behind the plastic and the sound isn't as bad anymore, though when on hard bumps on the road, the plastic still makes the sound. Here's a picture of what the dealer did.
![](http://www.pbase.com/thealbert/image/114207210.jpg)
![](http://www.pbase.com/thealbert/image/114207211.jpg)
![](http://www.pbase.com/thealbert/image/114207212.jpg)
![](http://www.pbase.com/thealbert/image/114207209.jpg)
The sound is still there, though I must admit, not as bad, BUT it's still there! I'm tempted to just open it up again and lay tape everywhere on the inside!
Anyone else got a better solution to get rid of the sound once and for all?
The center console part still bugs me to hell and back though! grrrr.
I was amazed when i saw those photos. I had the worst nightmare inside my brand new car and I am watching it every day. I don't know some how a spider enter inside my cluster and died there.It is in the center of the speedometer and it does not going off. I need to open the cluster but I need someone to explain to me how he remove that plastic cover that you show on your photos. can you please explain that to me. I will be a happy man if you can assist me as my dealer told me to live it as it is.Imagine that!!
#34
W204 C280
Hello there.
In order to remove your cluster, you first need to remove the trim that surrounds your cluster. This is the black plastic trim that looks like it wraps around the opening of where the cluster is installed. In order to remove this trim, insert a plastic knife or thing prying tool at the top of the trim. In between the trim and the dashboard. 1/3 of the way to the left and also 1/3 of the way to the right. You'll then need to twist it and the top part of the trim will pop down. Then pull on the bottom part of the trim. Don't worry about putting some force into pulling out the bottom part as this is just held on my friction. Might need a good yank so don't be shy. But be sure you pop down the top part first!
Once that trim is off, you will see the entire cluster. There are 4 screws you need to remove. You will need a torx 20 screwdriver for it. Remove the 4 screws and pull out the knob for the cluster dimmer control. Just pull it out as that's also held on my friction. Once all 4 screws and the dimmer knob has been removed, remove the cluster by removing it from the top first, folding down towards you. Make sure though that you have the steering wheel in the farthest position as you will need the space in order to get the cluster out of its place. This will require some angling as you remove the cluster from its place. Make sure you remove the wire clip from the rear as well.
Once the cluster is totally out from you car, you'll notice that the cluster is essentially two halves, held together by clips. Just pry out the clips out of their positions and then you'll have access to the internals of the cluster. You should be able to get the spider out already.
Hope this helps!
PS: Make sure you do not start the car when the cluster is not installed. I haven't tried it yet but my dealer advised me not to do so. Something to do with the immobilizer or sort.
#35
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Yes, its just another connector to disconnect.
We have had a couple of cars with "interior" rattles, but in both cases the sound came from the engine bay, it was the vacuum hose to the brake booster as well as a connector close to the firewall that caused rattles at a certain frequency.
#36
1 Post
axe muderer with headlights
How do you remove the LCD part? I was able to take out the vents, but was unable to remove the LCD unit. I didn't want to force it and break something.
I could tilt up but then I couldn't slide it out, the door kept getting caught in the dash.
Any hints for me?
Any hints for me?
#37
Rattle in center console
Guys, I had the same issue, actually there are two. First when I bought my w204 after 42000 km i had a rattle in the instrument cluster rim, which was fixed by the authorized dealer and I have no idea how (not type of a guy that does things on his own).
Later on, I had this rattle coming from the center speaker, even though I have no center speaker, but the area there. It still drives me crazy and have no idea how to solve it, neither the dealer knows. While in the dealer i tried to take it off and drive without the mask covering it and it did fine. Then i tried to put the mask without the parktronic meter, it was better and not much rattle. Once i plugged in the parktronic meter the noise is unbearable. I tried putting in felt as per instructions of some users in the forum, but didnt work, tried doubling and tripling the felt, yet didnt work
Whomever finds a solution (except super gluing all the area), you name the gift... it just drives me crazy.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#38
2011 CLS 350 CDI Coupe
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
I couldn't take the rattling anymore so I decided to try a little DIY. Sorry if it looks horrible (this is my first attempt on it on my own) but believe it or not, it actually works!
The rattling isn't as bad anymore and instead of hearing an annoying "tick, tick" all the time, its more of a bearable "tok" every now and then. Not as high pitched. It also only occurs when I drive over big bumps or very rough roads. Unlike before, it would just keep rattling away. Though if I listen very carefully, the rattle is still there since I found that the rattle is coming from either the instrument cluster or behind it. But the foam does help a lot and really muffles out the sound.
For the foam, I used DynaLiner, 1/4in thick but for some parts, I had to trim it down to make it thinner. I also used orange electrical tape as a base since the Dynaliner is self adhesive and the adhevise is very strong and I was afraid that if I make any mistakes, I wouldn't be able to remove the Dynaliner anymore. With electrical tape as my base, removing the Dynaliner is easy and doesn't leave any traces.
Here are some pictures.
![](http://www.pbase.com/thealbert/image/114318656.jpg)
![](http://www.pbase.com/thealbert/image/114318657.jpg)
![](http://www.pbase.com/thealbert/image/114318658.jpg)
I know it looks horrible but I just wanted to see if it works and it seems like it does. When I have the time, I'm going to go back and clean it up nicer, but the lazy bum in me kinda doesn't feel like going it anymore since I don't see the mess anyway.
Now all I gotta figure out is how to get rid of the center speaker rattle.
Now, I could of let MB taken care of it - since the car is still under warranty, but my gut instinct tells me - they would of just made a half-*** job of it- put a few tape on edges and, most likely the noise would still persist....
Anyway, yours was a good start - to which I modified it slightly with xtra adhesive double sided tape, which I stuck on 'flet' to stop certain friction parts from making contact with one another. What I have noticed with my W212 is that the majority of clips which are on the plastic shroud were 'felted', and some were missing...so I made sure these were done. The next thing I done - like you, was to pad the inner plastic with the double sided tape (note my tape is padded) and then cut some kitchen cloth to replicate the felt material to which I stuck on the tape. I could't really pad it up using foam - as the fitting is not entirely the same as yours above.
Well..the result is..no noise after the test run!! Think I have cured the problem! Only time will tell tomorrow when I take it out from cold. Will report back to the board ASAP! So..hats off to you as we say in England! A jolly well done!!
#39
MY rattle cure update
Dear all,
As promised, I'll update you on the noise fix....well, this morning I took the car out on the rough road and.....YAY!!! That horrid 'tick-tick' noise has now disappeared! I even took the car into even rougher ground to seee the tolerances and still nothing! I'm so happy with the results and a big big thank you for albert101 DIY thread!!
#40
Confirmed
I just wanted to to reiterate on your findings - it is the interface where the plastic trim meets the dashboard speedometer clear plastic cover. It was where my 'tick-tick' noise problem was. Tip I would give, is to wedge a bit of cloth between the trim/dash cover so it won't rub. I'm sure this will solve a lot of problems. Just a shame MB didn't make that platic trim out of some sort of rubber/leather composit to absorb movements.
