Custom Work Wheels Installed!
1 Post
w204 - 350 N other white cars
nice wheelz illusive..![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
hehheh.. i didn't know it was u until your reply...![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
..u didn't lower your ride right? my setup is not to lower mine cause i driving conditions over here doesn't permit me too..
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Please find out what offset you are running.
Illusive: The car looks great!!
One question though, I also have a 4Matic and want to do the staggered setup and was wondering if you had any issues with the tire sizes since yours is also a 4matic? The tire sizes you mentioned in your first post, are they the correct sizes to run on the staggered setup on this car?
Just trying to get some answers before I order tires for the rims I like.
Thanks for the feedback!
2012 C63 AMG
I tried looking inside the wheel to see if there was a sticker with the dimensions, but nothing. It is probably stamped behind the spokes, but I won't be able to see it until I remove the wheels for winter storage. I'll call my supplier and see if he can give me the dimensions he used when he ordered them for me.
Thanks! Nope, if you have a good tuner shop in your area, they should have a lot of information regarding the diameter of each tire that you could put on the wheels. The specs that were selected for my wheels were chosen based on the diameter. I believe they are within a few millimeters in diameter. They should be what you use unless you want to go with a wider tire in which case you'd need to get a different size on the side wall to match. Make sure you check the diameter, lots of places do not do this and just throw whatever size they think is good enough or cheapest option without checking. I think I only had a few choices in those dimensions.
Yes they did! Very happy with them though, custom fit wheels are definitely the way to go if you want them to look the best and not just a generic set. Don't know if I will ever shell out that much again for wheels, I'm getting old lol!
