GPS retrofit SCN coding / MOST ring
The dealer I have been working with on this had my car for the past two days. They went through MB Premier (?) to have them get an FDOC(?) to re-image my data card (ECU?) from Germany. MB Premier told them that in order to do this on a 424 coded car (US market) it would void the entire warranty. Apparently they did this for a car in Cali and f'ed it up.
If anyone has successfully done this in the US, can you PM me the dealership that you went through. I am going to try another dealer but am starting to doubt that someone will actually be able to do it.
The first time I took it in I noticed that they had added SDARS in the MOST ring but it still wasn't showing up.. Today I was pissing around in Engineering mode and noticed that under 7.5 (TGW Parameter) SDARS was set to not installed. I flipped that around and everything is working great now.
Now if I can only convince them that it is a good idea to change the 5km/h setting for VIM....
We also have a local service shop that focuses on German cars and exotics. I may give them a call and see if they have the stuff to take care of it.
